DataAssist Update Page showing 01/01/1970
Thread began 3/13/2010 8:19 am by fabianmacs370894 | Last modified 3/15/2010 1:45 pm by Eric Mittman | 1538 views | 1 replies |
fabianmacs370894
When I change the date on the update page it just displays 01/01/1970. Insert page works fine and posts correctly to DB.
I am using on update page:
$WA_fieldValuesStr = "".((isset($_POST["event_date"]))?date("Y-m-d", strtotime($_POST['event_date'])):"") ."" . "|" . "".((isset($_POST["event_name"]))?$_POST["event_name"]:"") ."";
On my date form code is:
<?php echo date('d/m/Y',strtotime($row_WADAdatetestTbl['event_date'])); ?>
Any solutions to updating date to new date using dd-mm-yyyy?
Thanks in advance.
datetestTbl_Update.php.zip
Have you checked on this record in the db to confirm the value that it was updated to? Rite now I'm not sure if the problem is when you are updating the date, or when you are displaying it again after it has been updated. If you can check the record in the db to confirm that the proper date is being updated it would indicate a problem with the display of the date on this page.
