Checkout button not working!!!!
Thread began 3/13/2010 7:18 am by matt374640 | Last modified 3/15/2010 10:08 am by Jason Byrnes | 934 views | 1 replies |
matt374640
I have my cart.php on the test server and one item in the cart. Now I press the button checkout, but nothing is happening. Nothing at all. I checked the address it is "checkout.php"
I even checked the full address with "http://localhost/..../checkout.php" no reaction at all. All the rest is working. So it would be ready to go online... The only thing, which I have done, was moving the checkout.php page from another directory to the same directory like cart.php. That makes it then later on easier to work with https://
First, check the eCart Checkout button server behavior on the cart.php page.
In the Server Behavior panel, double click the eCart Checkout button server behavior and make sure it is pointing to the checkout page.
if it is still not working, there may be a php error occurring that is causing the redirect to fail, add the following code to the checkout page at line1 to turn error reporting on:
error_reporting
(E_ALL);
