adding title to menu item
Thread begun 3/13/2010 3:10 am by software.current355386 | Last modified 3/15/2010 9:48 am by Jason Byrnes | 2479 views | 4 replies |
is there anyway of adding the title attibute without manually adding it to the generated source
John LangerBeta Tester
There is a way.
Open up the "Tag Inspector" panel.
Select the "Attributes" tab
Click on "CSS/Accessibilty" to open it and at the bottom is an area where you can type (or paste) your "Title" text.
that woks ok untl you regenerate / rebuid using menu writer they are then lost.
what i was hoping forwas to be able to defime within mw so they are not lost.
this would help me greatly. maybe aan enhaaancement possibiLitY
I'm sorry Kevin I didn't read the title of your post, therefore not realising that you were talking about MenuWriter.
I'm afraid that I'm not familiar enough with the extension to give a specific reply.
Hopefully a WebAssist employee will get back to you on this or another "Expert".
No, the menu writer does not offer a way to add a title attribute. I will add a feature request to have this considered for a future version.
