Calculate Difference in Time with PHP
Thread begun 3/12/2010 10:57 am by tom92909 | Last modified 3/15/2010 1:47 pm by Justin Nemeth | 3537 views | 2 replies |
tom92909Beta Tester
Howdy folks! :)
I've been working on a new project that calculates hours worked. I need to take up to three 24hr clock IN and clock OUT entries stored in MySQL and come up with a calculated sum difference in time.
I've seen lots of examples from folks via Google searches, but I'm stuck. I can't seem to get the the calculations right.
I am storing up to a possible 3 entries per/work day. Below is my weak attempt to get started...
$query = "SELECT * FROM emphours
        WHERE `Date` BETWEEN '".$_POST['Start']."' and '".$_POST['End']."'";
    $time1=$row["Out1"]-$row["In1"];
    $ext1 = "$time1:";
    $time2=$row["Out2"]-$row["In2"];
    $ext2 = "$time2:";
    $time3=$row["Out3"]-$row["In3"];
    $ext3 = "$time3:";
    $ExtTot = $ext1 + $ext2 + $ext2;
I found a web tool that is an outstanding example of what I'm trying to accomplish, except I need to make some modifications to suit my exact requirements... I'm attempting to contact the author/website owner to gain some insight.
timesheet.php
The scripting this site has is right on target.
Any tips, pointers, suggestions would be greatly appreciated.
Tom
you could do this all in your query.
the sql function for subtracting two times is TIMEDIFF, for adding two times ADDTIME
heres an example query using real time values:
SELECT TIMEDIFF('2010-12-24 12:13:44','2010-12-24 04:15:44') as time1, TIMEDIFF('2010-12-22 11:13:44','2010-12-22 02:15:44') as time2, TIMEDIFF('2010-12-20 9:13:44','2010-12-20 5:15:44') as time3, ADDTIME(TIMEDIFF('2010-12-24 12:13:44','2010-12-24 04:15:44') ,ADDTIME(TIMEDIFF('2010-12-22 11:13:44','2010-12-22 02:15:44'), TIMEDIFF('2010-12-20 9:13:44','2010-12-20 5:15:44'))) AS totalHours;
or to use the columns in your DB:
SELECT TIMEDIFF(Out1, In1) as time1, TIMEDIFF(Out2, In2) as time2, TIMEDIFF(Out3, In3) as time3, TIMEADD(TIMEDIFF(Out1, In1) ,TIMEADD(TIMEDIFF(Out2, In2), TIMEDIFF(Out3, In3))) AS totalHours
Justin Nemeth
A cool PHP function to look into is strtotime(). Basically you can manipulate a date/time string pretty easily.
strtotime
