Looks nice, multiple galleries to an end user?
Thread begun 3/12/2010 6:37 am by CraigR | Last modified 3/15/2010 10:03 am by CraigR | 2726 views | 4 replies |
CraigRBeta Tester
I just bought powergallery, and i think it looks really nice, the installation was a breeze.
I have a photographer friend / client for whom this looks like a really good solution.
What i would like to do is give him the ability to add a new page with a gallery embedded, without any input from me, via an interface.
i can configure a 'content' page so that the menu is fed from a database, so links can be added to any new pages
how could i provide an 'add new page' facility ?
I looked at the PowerCMS documentation, but this seems to allow only content editing, but not page creation.
Power CMS does not have the ability to create a new page automatically, you would need to hand code a script for creating the new page and add the gallery code to it.
I found the following tutorial through google:
php-create-a-file-on-your-server/
this may be helpful for getting started with creating the new page.
CraigRBeta Tester
great link
thanks for the url Jason, that gives me a great start...
now here's the $64000 question !
i have edited the script as below, passing in the appropriate html, as a string, line by line with line breaks,building it up slowly so as to recreate a blank page with the appropriate layout.
$filename = 'testnewpage.php';
$Content = "".'<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">'."\r\n".
'<html xmlns="http://www.w3.org/1999/xhtml">'."\r\n".
'<head>'."\r\n".
'<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />'."\r\n".
'<title>Page Title</title>'."\r\n"."";
echo "open";
$handle = fopen($filename, 'x+');
echo " write";
fwrite($handle, $Content);
echo " close";
fclose($handle);
You get the idea.
is what i have achieved so far the best way to achieve my objective ?
thanks for your support
that looks good, you would want to further modify $Content to build up the body of the page as well.
you could add a create page button to the admin section on the add to site page that will take the code for the gallery and automatically add it in.
CraigRBeta Tester
great
Thanks Jason, i just wanted to check i was on the right lines.
As all of my gallery viewing pages will be based on the same recordset, what i have done so far is to use a php includes for the recordset code and just a few lines for the css import and everything in the <body> tags
i added the code to a dataassist 'insert new record' page, so i add a row to the appropriate table, populating the title tag fields and a few others, and create a standard gallery page which reads this data from the table.
i then use an update record page to insert the appropriate gallery code to my content.
early days, but looking good.
thanks for your help
