Line item 1 is invalid(Cant find solution in forums)
Thread begun 3/11/2010 12:56 pm by Nenad | Last modified 3/12/2010 5:08 pm by Jimmy Wu | 2314 views | 4 replies |
Nenad
Hello,
I am receiving the error "Line item 1 is invalid." I have looked at all relevant posts on the subject and tried all solution currently available in this forum with no avail.
When we look at the full request below there doesn't seem to be 'line_item=1'. There is a 'line_item=2', but no 'line_item=1'
The Name does not have any HTML characters in it. The description field is empty. I also tried putting a value in this field but still doesnt work. I created a new unique column in ecart called "Package" that also does not contain any HTML characters. This column is supposed to pass through, hopefully I did this correctly. In the database the ProductName is varchar(100) and Package is varchar(50).
Im not sure what to try any more. Please help! The responses are below, I replaced all of my personal information with *. I also attached the confirm.php.
Thank you in advance for you help. And please, I need a solution ASAP, this is very important. THANK YOU SO MUCH!
****ERROR****
3
1
270
****FULL RESPONSE****
3::1::270::Line item 1 is invalid.::::P::0::4j29sceaeq640hl77vpa::1 Playboy Golf (2)::1.00::CC::auth_capture::::*******************::::**************::Elmhurst::IL::*****::US::*******************::::*********************::*****::*******vsic::::*****************::*************::**::*****::US::::::::FALSE::::7DC89A59B81120B256371D7F5AC60639::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::*************::
****FULL REQUEST****
x_login=*******************x_tran_key=****************&x_version=3.1&x_invoice_num=4j29sceaeq640hl77vpaaqugf2&x_test_request=FALSE&x_method=CC&x_type=AUTH_CAPTURE&x_relay_response=FALSE&x_delim_data=TRUE&x_delim_char=::&x_customer_ip=*****************&x_amount=1.00&x_description=1 Playboy Golf (2)&x_line_item=2<|>Playboy Golf<|>TEST PRODUCT<|><|>1<|>1<|>YES&x_card_num=*******************&x_exp_date=****&x_card_code=***&x_email_customer=TRUE&x_tax_exempt=FALSE&x_first_name=*********&x_last_name=*************&x_address=******************&x_city=Elmhurst&x_state=**&x_zip=**************&x_phone=**************&x_fax=&x_email=****************&x_country=US&x_ship_to_first_name=************&x_ship_to_last_name=*************&x_ship_to_address=*****************&x_ship_to_city=*****************&x_ship_to_state=**&x_ship_to_zip=*****&x_ship_to_country=US&x_ship_to_phone=*************&x_ship_to_fax=&x_currency_code=USD&x_recurring_billing=NO
Nenad
Nevermind.....solved
Nevermind my thread, it is solved now.
Thanks!
Jimmy Wu
It would be very much appreciated if you could post up your resolution to the issue in case any other users run into the same issue. Thanks, and I'm glad you were able to get your issue resolved. If you run into any additional issues, feel free to open a new thread.
Nenad
Hey Jimmy,
I just had some junk code that was throwing it off. Unfortunately it is nothing that can help anyone here. It was just some code that I tried adding for another feature, once I removed it it worked.
Nick
Jimmy Wu
Ah, well, glad you got it resolved.
