Problems uploading images in new release
Thread begun 3/11/2010 11:27 am by web364946 | Last modified 3/11/2010 2:10 pm by Eric Mittman | 1702 views | 1 replies |
web364946
When trying to upload images I get the error message below:
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/customers/landosjon.se/landosjon.se/httpd.www/CMS101/HTMLEditor/editor/plugins/kfm/plugins/jwplayer.zip/plugin.css) is not within the allowed path(s): (/customers/landosjon.se/landosjon.se:/var/www/diagnostics:/usr/share/php) in /customers/landosjon.se/landosjon.se/httpd.www/CMS101/HTMLEditor/editor/plugins/kfm/index.php on line 91
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/customers/landosjon.se/landosjon.se/httpd.www/CMS101/HTMLEditor/editor/plugins/kfm/plugins/jwplayer.zip/plugin.php) is not within the allowed path(s): (/customers/landosjon.se/landosjon.se:/var/www/diagnostics:/usr/share/php) in /customers/landosjon.se/landosjon.se/httpd.www/CMS101/HTMLEditor/editor/plugins/kfm/index.php on line 211
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/customers/landosjon.se/landosjon.se/httpd.www/CMS101/HTMLEditor/editor/plugins/kfm/plugins/jwplayer.zip/plugin.js) is not within the allowed path(s): (/customers/landosjon.se/landosjon.se:/var/www/diagnostics:/usr/share/php) in /customers/landosjon.se/landosjon.se/httpd.www/CMS101/HTMLEditor/editor/plugins/kfm/index.php on line 212
How do I solve this?
The errors here are telling you that the open base dir directive is in effect. When this is set you can only include files that are within the specified path. In order to use include files you will either need to move all included files into the directory specified and update the paths or turn this restriction off. It would be much easier to turn this off. Depending on how it is set either directly in the ini or with safe mode being on you may need to contact your host to alter this setting.
