PS3 Problems with PayPal Express Checkout
Thread begun 3/11/2010 10:34 am by Tom M | Last modified 3/24/2010 2:45 pm by stuff223820 | 10013 views | 27 replies |
Tom M
I've configured and populated my PS3 store and am having a big problem with PayPal Express Checkout.
  1. I initiate the checkout process and I am directed to the PayPal site to make a payment
  2. I go through the login process and specify payment method, etc.
  3. I am then returned to my PS3 Confirmation Page where there is *no* information related to PayPal Express Checkout Info or Shipping Info. (see attached screenshot).
I *have* tested this using my PayPal dev sandbox and it works there. Is there some PayPal account parameter I need to set up other than the API credentials in order to get this to work?!
Thanks,
TM
i.edwards384429
update
Hi
I'm having exactly the same issue, which support and I are trying to sort.
In my case it apparently is faulty API credentials.
I am attempting to locate paypal support email/phone number because apparently it's thier problem.
Watch this space
cheers
Ian
Tom M
I don't know how you got your API credentials into PS3, but I copied and pasted the ones I am using directly out of the PayPal API screen. If you did the same, how could they be faulty?
Is there some diagnostic code we can drop into the Confirmation page to provide more info?
i.edwards384429
update
Hi
on the first occasion I copied and pasted, on the second I copied them into notepad.
I finaly selected view source and copied and pasted from the HTML code.
My last test was to create a new api set using my own payupal account however it appears these credentials were wrong as well.
I have two shops waiting to launch but neither appear to work with Paypal UK
really weird.
Wish I could give you a solution but in a way I'm happy because at least I know it's not me
cheers
Ian
Tom M
Were you able to test your stores successfully in a PayPal Dev Sandbox?
I tested mine and everything was great. I try to go live and pow! it doesn't work.
i.edwards384429
Update
Hi again
forgot yes there is code to put in: ( not from me from tech support)
To add this into the page open up your pp_confirm and go into split view. Select the area of the page where it lists the PayPal Express Checkout Info, in here past the following code into the code area:
full request for get profile is: <?php echo $WA_PP_ECO_GetResult->fullRequest; ?><br/>full response for get profile is: <?php echo $WA_PP_ECO_GetResult->fullResponse; ?>
The results meant zero to me but according to support they indicate bad credentials
Cheers
Ian
There is a larger set of debug code to help determine what the problem with the checkout might be. You can add this code into any of the checkout pages to see the status of the interaction with the PayPal API, just add the code where you would like to see the info:
if(!session_id()) session_start();
 if(
$WAGLOBAL_Gateway == 1 ) {
     echo
"<p>Direct Pay: <br />";
     echo
"Full Request: ".(isset($_SESSION["PP_DirectPayment_postedValues"])?htmlentities($_SESSION["PP_DirectPayment_postedValues"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["PP_DirectPayment"])?htmlentities($_SESSION["PP_DirectPayment"]):"n/a")."<br /></p>";
     echo
"<p>Express Authorize <br />";
     echo
"Full Request: ".(isset($_SESSION["ECO_Auth_Request"])?htmlentities($_SESSION["ECO_Auth_Request"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["ECO_Auth_Result"])?htmlentities($_SESSION["ECO_Auth_Result"]):"n/a")."<br />";
     echo
"<p>Express Process: <br />";
     echo
"Full Request: ".(isset($_SESSION["ECO_Process_Request"])?htmlentities($_SESSION["ECO_Process_Request"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["ECO_Process_Result"])?htmlentities($_SESSION["ECO_Process_Result"]):"n/a")."<br /></p>";  }
 if(
$WAGLOBAL_Gateway == 2) {
     echo
"<p>Auth Net: <br />";
     echo
"Full Request: ".(isset($_SESSION['WAAuthNet_postedValues'])?htmlentities($_SESSION['WAAuthNet_postedValues']):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION['WAAuthNet'])?htmlentities($_SESSION['WAAuthNet']):"n/a")."<br /></p>";  }
  if(
$WAGLOBAL_Gateway == 3 ) {
     echo
"<p>Express Authorize: <br />";
     echo
     echo
"Full Response: ".(isset($_SESSION["ECO_Auth_Result"])?htmlentities($_SESSION["ECO_Auth_Result"]):"n/a")."<br /></p>";
     echo
     echo
     echo
 if(
$WAGLOBAL_Shipping == 1) {
     echo
"<p>UPS: <br />";
     echo
"Full Request: ".(isset($_SESSION["WA_Store_Cart_UPS_FullRequest"])?htmlentities($_SESSION["WA_Store_Cart_UPS_FullRequest"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["WA_Store_Cart_UPS_FullResponse"])?htmlentities($_SESSION["WA_Store_Cart_UPS_FullResponse"]):"n/a")."<br /></p>";  }  if($WAGLOBAL_Shipping == 2) {
     echo
"<p>FedEX: <br />";
     echo
"Full Request: ".(isset($_SESSION["WA_Store_Cart_FedEx_FullRequest"])?htmlentities($_SESSION["WA_Store_Cart_FedEx_FullRequest"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["WA_Store_Cart_FedEx_FullResponse"])?htmlentities($_SESSION["WA_Store_Cart_FedEx_FullResponse"]):"n/a")."<br /></p>";  }  if($WAGLOBAL_Shipping == 3) {
     echo
"<p>USPS: <br />";
     echo
"Full Request: ".(isset($_SESSION["WA_Store_Cart_USPS_FullRequest"])?htmlentities($_SESSION["WA_Store_Cart_USPS_FullRequest"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["WA_Store_Cart_USPS_FullResponse"])?htmlentities($_SESSION["WA_Store_Cart_USPS_FullResponse"]):"n/a")."<br /></p>";  } ?>
There should be an error message and number that is returned that you could look up within the PayPal API reference to tell you just what the error means. If you have a hard time determining what the error is that you are getting let us know and we can look into this response with you. You can post the response that you get here on the forum but remember to remove any sensitive details from it first.
i.edwards384429
update
Hi
couple of things that might be of interest to you
I've noticed you can go all the way through to the paypal site with out registering as a user. Not sure if this is good or bad
Second I ran the code eric left for you on my site and got whats below:
I have checked the three credentials (deleted here) and they are identical to the paypal issued details.
Isn't life fun?
Ian
Express Authorize:
Full Request: <?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><soap:Header><RequesterCredentials xmlns="urn:ebay:api:PayPalAPI"><Credentials xmlns="urn:ebay:apis:eBLBaseComponents"><Username>DAVID.GARVEY_api1.xxxxxx.COM</Username><Password>UC</Password><Signature>AFT3vDXNtFoWWP2aFdr6</Signature><Subject/></Credentials></RequesterCredentials></soap:Header><soap:Body><SetExpressCheckoutReq xmlns="urn:ebay:api:PayPalAPI"><SetExpressCheckoutRequest><Version xmlns="urn:ebay:apis:eBLBaseComponents">2.20</Version><SetExpressCheckoutRequestDetails xmlns="urn:ebay:apis:eBLBaseComponents"><OrderTotal currencyID="GBP">1.00</OrderTotal><ReturnURL>http://www.mbsuk.co.uk/pp_confirm.php</ReturnURL><CancelURL>http://www.mbsuk.co.uk/pp_cancel.php</CancelURL><PaymentAction>Authorization</PaymentAction></SetExpressCheckoutRequestDetails></SetExpressCheckoutRequest></SetExpressCheckoutReq></soap:Body></soap:Envelope>
Full Response: <?xml version="1.0" encoding="UTF-8"?><SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:cc="urn:ebay:apis:CoreComponentTypes" xmlns:ed="urn:ebay:apis:EnhancedDataTypes" xmlns:wsu="http://schemas.xmlsoap.org/ws/2002/07/utility" xmlns:saml="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:wsse="http://schemas.xmlsoap.org/ws/2002/12/secext" xmlns:ebl="urn:ebay:apis:eBLBaseComponents" xmlns:ns="urn:ebay:api:PayPalAPI"><SOAP-ENV:Header><Security xmlns="http://schemas.xmlsoap.org/ws/2002/12/secext" xsi:type="wsse:SecurityType"></Security><RequesterCredentials xmlns="urn:ebay:api:PayPalAPI" xsi:type="ebl:CustomSecurityHeaderType"><Credentials xmlns="urn:ebay:apis:eBLBaseComponents" xsi:type="ebl:UserIdPasswordType"><Username xsi:type="xs:string"></Username><Password xsi:type="xs:string"></Password><Signature xsi:type="xs:string">AFT3vDXNtFoWWP2aFdr6yLxBX5p.AGDwxI7l5W.xbPzgZwIyTgsPVafw</Signature><Subject xsi:type="xs:string"></Subject></Credentials></RequesterCredentials></SOAP-ENV:Header><SOAP-ENV:Body id="_0"><SetExpressCheckoutResponse xmlns="urn:ebay:api:PayPalAPI"><Timestamp xmlns="urn:ebay:apis:eBLBaseComponents">2010-03-11T20:56:26Z</Timestamp><Ack xmlns="urn:ebay:apis:eBLBaseComponents">Success</Ack><CorrelationID xmlns="urn:ebay:apis:eBLBaseComponents">86907a8f24f3c</CorrelationID><Version xmlns="urn:ebay:apis:eBLBaseComponents">2.20</Version><Build xmlns="urn:ebay:apis:eBLBaseComponents">1227335</Build><Token xsi:type="ebl:ExpressCheckoutTokenType">EC-2CN0094953126153X</Token></SetExpressCheckoutResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
Express Process:
Full Request: n/a
Full Response: n/a
Tom M
Security errorSecurity header is not valid10002Error2.201227335unverified
Tom M
I spoke with PayPal Tech Support after talking to several other people and then sitting on hold for a looooong time. The tech support person said that while the "Set Express Checkout" API call is going to the "correct endpoint", either the "Get Express Checkout Payment Detals" or the "DoExpressCheckoutPayment" API call is going to the wrong endpoint possibly a sandbox.
The net-net to me is that it doesn't work and I'm caught between WebAssist and PayPal Tech Support.
TM
