After Form Submits, it goes back to the same page
Thread begun 3/11/2010 9:53 am by dinohorn397192 | Last modified 3/11/2010 4:10 pm by dinohorn397192 | 3665 views | 6 replies |
dinohorn397192
I attached the code, I have looked at it for a long time and can't find anything wrong with it. The data gets submitted the database successfully.
dinohorn397192
FYI: I used CSS Form Builder to create the form and DataAssist Insert Single Record.
Thanks again
the following code is preventing the header() function from redirecting the page:
echo "Starting to output current session data";
print_r($HTTP_SESSION_VARS);
if you where to add this code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
you would see that there is Headers Already Sent error occurring.
the headers already sent error occurs if there is any output to the page before the session-start() or header() functions are called. you code:
is causing the output to the page, which is preventing the header() function from executing.
dinohorn397192
Thanks for the quick reply. I removed ..
// this starts the session
session_start();
// echo variable from the session, we set this on our other page
and put in the error output message you showed me. When they page loads, I still get a header error (image attached). When I submit, I sent the second error (image attached).
Sorry, I'm new to php... I guess I was trying to session_start() twice on one page. It's still doing the same thing.
dinohorn397192
This is line 89, from the second screenshot.
see the following page for information on the headers already sent error:
148/
dinohorn397192
Thank you! It was 1 whitespace after a "?>" !!!!
