Issues with registration page...
Thread begun 3/11/2010 7:53 am by fdotmedia | Last modified 3/11/2010 3:21 pm by Jason Byrnes | 3667 views | 7 replies |
fdotmedia
I want to, in our register page, have an email address, password and set organizations and exclude people from registering if they DO NOT have a correct organization or 'orgcode'...
I have done it two different ways:
~ register2.php - lets anyone register with any value in the 'orgcode' input field
~ register1.php - denies everyone regardless whether the 'orgcode' is correct
I'm kinda at my wits end... Can someone help please???
Thanks,
Ted
your on the right track with register1.php, using server validation to validate the number of rows in the orgcode recordset.
the problem is the code order.
The Validation occurs at lines 4 - 18, but the recordset is not created until lines 98 - 102.
delete the code at line 98 - 102:
mysql_select_db($database_Users, $Users);
$query_orgcode = "SELECT * FROM orgcode";
$orgcode = mysql_query($query_orgcode, $Users) or die(mysql_error());
$row_orgcode = mysql_fetch_assoc($orgcode);
$totalRows_orgcode = mysql_num_rows($orgcode);
and lines 19 - 50:
if (!function_exists("GetSQLValueString")) {
function
GetSQLValueString($theValue$theType$theDefinedValue ""$theNotDefinedValue ""
  if (
PHP_VERSION 6) {
$theValue get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
  switch (
$theType) {
    case
"text":
$theValue = ($theValue != "") ? "'" $theValue "'" "NULL";
      break;
    case
"long":
    case
"int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
      break;
    case
"double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
      break;
    case
"date":
      break;
    case
"defined":
$theValue = ($theValue != "") ? $theDefinedValue $theNotDefinedValue;
      break;
  return
$theValue;
then insert the following code at line 4:
function
  if (
PHP_VERSION 6) {
  switch (
$theType) {
    case
"text":
      break;
    case
"long":
    case
"int":
      break;
    case
"double":
      break;
    case
"date":
      break;
    case
"defined":
      break;
  return
$theValue;
mysql_select_db($database_Users$Users);
$query_orgcode "SELECT * FROM orgcode";
$orgcode mysql_query($query_orgcode$Users) or die(mysql_error());
$row_orgcode mysql_fetch_assoc($orgcode);
$totalRows_orgcode mysql_num_rows($orgcode);
fdotmedia
No matter what combination of username, password and orgcode I put in - even if it's an existing user, which is supposed to redirect to duplicate.php, it only goes to access-denied.php...
Below is the code on the page...
<?php require_once('../Connections/Users.php'); ?>
<?php require_once("../WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("../WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
if ((((isset($_POST["Register"]))?$_POST["Register"]:"") != "")) {
$WAFV_Redirect = "access-denied.php";
$_SESSION['WAVT_register1_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateNM($totalRows_orgcode . "",-1,0,"",",.",true,1);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"register1");
// *** Redirect if username exists
$MM_flag="MM_insert";
if (isset($_POST[$MM_flag])) {
$MM_dupKeyRedirect="duplicate.php";
$loginUsername = $_POST['emailaddress'];
$LoginRS__query = sprintf("SELECT emailaddress FROM users WHERE emailaddress=%s", GetSQLValueString($loginUsername, "text"));
$LoginRS=mysql_query($LoginRS__query, $Users) or die(mysql_error());
$loginFoundUser = mysql_num_rows($LoginRS);
//if there is a row in the database, the username was found - can not add the requested username
if($loginFoundUser){
$MM_qsChar = "?";
//append the username to the redirect page
if (substr_count($MM_dupKeyRedirect,"?") >=1) $MM_qsChar = "&";
$MM_dupKeyRedirect = $MM_dupKeyRedirect . $MM_qsChar ."requsername=".$loginUsername;
header ("Location: $MM_dupKeyRedirect");
exit;
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "WAATKRegistrationForm")) {
$insertSQL = sprintf("INSERT INTO users (emailaddress, password, orgcode, receiveEmails) VALUES (%s, %s, %s, %s)",
GetSQLValueString($_POST['emailaddress'], "text"),
GetSQLValueString($_POST['password'], "text"),
GetSQLValueString($_POST['orgcode'], "text"),
GetSQLValueString($_POST['receiveEmails'], "text"));
$Result1 = mysql_query($insertSQL, $Users) or die(mysql_error());
$insertGoTo = "login.php";
$insertGoTo .= (strpos($insertGoTo, '?')) ? "&" : "?";
$insertGoTo .= $_SERVER['QUERY_STRING'];
header(sprintf("Location: %s", $insertGoTo));
edit the org code recordset to filter the orgcode column on the org code form element.
fdotmedia
I changed this...
to this...
$query_orgcode = sprintf("SELECT * FROM orgcode WHERE orgcode = %s", GetSQLValueString($colname_orgcode, "text"));
And it allows anyone to register...
please posta copy of the page so I can see the entire code in context.
fdotmedia
Thanks Jason
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$WAFV_Errors = "";
$MM_qsChar = "?";
exit;
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN" "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">
<head>
<meta http-equiv="Content-Type" content="application/xhtml+xml; charset=UTF-8" />
<title>My Personal Health Journal .:. Please Register!</title>
<meta name="keywords" content="employee health, employees, employees health, wellness, wellness education, healthy Quarters, HealthyQuarters, healthyquarters.net, my personal health journal" />
<meta name="description" content="Healthy employees make healthy companies and the difficulty is getting and keeping a workforce healthy and motivated. That's where My Personal Health Journal comes in." />
<link rel="stylesheet" type="text/css" media="screen, print, projection" href="../login.css"></link>
<script src="../SpryAssets/SpryValidationTextField.js" type="text/javascript"></script>
<script src="../SpryAssets/SpryValidationPassword.js" type="text/javascript"></script>
<link href="../SpryAssets/SpryValidationTextField.css" rel="stylesheet" type="text/css" />
<link href="../SpryAssets/SpryValidationPassword.css" rel="stylesheet" type="text/css" />
</head>
<body>
<table align="center" width="820" height="675" background="../images/clogin.jpg" cellpadding="0" cellspacing="0">
<tr>
<td width="80"><img src="../images/spacer.gif" width="80" height="350" /></td>
<td height="350" width="360"><img src="../images/spacer.gif" width="360" height="350" /></td>
<td width="380"><img src="../images/spacer.gif" width="380" height="350" /></td>
</tr>
<tr>
<td width="80" valign="top"><img src="../images/spacer.gif" width="80" height="320" /></td>
<td valign="top" width="360" height="320">
<h2>Corporate Registration</h2>
<form action="<?php echo $editFormAction; ?>" method="post" name="WAATKRegistrationForm" id="WAATKRegistrationForm">
<table width="100%" border="0" align="left" cellpadding="6" cellspacing="0">
<tr>
<td align="right" class="login-sm" width="26%">Email Address:</td>
<td><span id="req-email">
<input type="text" name="emailaddress" id="emailaddress" value="" size="15" />
<span class="textfieldRequiredMsg">Required.</span><span class="textfieldInvalidFormatMsg">Email Address.</span></span></td>
</tr>
<tr>
<td align="right" class="login-sm">Password:</td>
<td><span id="req-pass">
<input type="password" name="password" id="password" value="" size="15" />
<span class="passwordRequiredMsg">Required.</span></span></td>
</tr>
<tr>
<td align="right" class="login-sm">OrgCode:</td>
<td><span id="req-orgcode">
<input type="text" name="orgcode" id="orgcode" value="" size="15" />
<span class="textfieldRequiredMsg">Required.</span></span></td>
</tr>
<tr>
<td align="right" class="login-sm">SPAM:</td>
<td style="font-size:10px">1 + 1 =<span id="req-math">
<input type="text" name="math" class="" id="math" size="5" />
<span class="textfieldRequiredMsg">Try the number 2.</span><span class="textfieldInvalidFormatMsg">Wrong answer.</span></span></td>
</tr>
<tr>
<td colspan="2" align="center">
<input type="Submit" name="Register" id="Register" value="Register"><br /> <span class="login-sm"><a href="email-pw.php">forgot your password?</a> | <a href="index.php">login</a> | <a href="contact-us.php">contact us</a></span>
<input type="hidden" name="receiveEmails" id="receiveEmails" value="" >
<input type="hidden" name="MM_insert" value="WAATKRegistrationForm">
</td>
</tr>
</table>
</form>
</td>
<td width="380" height="320"><img src="../images/spacer.gif" width="380" height="320" /></td>
</tr>
</table>
var sprytextfield1 = new Spry.Widget.ValidationTextField("req-math", "custom", {validateOn:["blur"], pattern:"2"});
var sprytextfield2 = new Spry.Widget.ValidationTextField("req-email", "email", {validateOn:["blur"]});
var sprypassword1 = new Spry.Widget.ValidationPassword("req-pass", {validateOn:["blur"]});
var sprytextfield3 = new Spry.Widget.ValidationTextField("req-orgcode", "none", {validateOn:["blur"]});
</script>
</body>
</html>
mysql_free_result($orgcode);
this code has a basic unfiltered query:
you ned to change it to filter the orgcode column on the posted orgcode form element.
