Any way to work with 3 decimal places internally and show rounded 2 decimal places?
Thread begun 3/11/2010 5:18 am by jernej | Last modified 3/11/2010 12:03 pm by jernej | 3842 views | 4 replies |
jernej
I have a problem. As I am adding some rules and each rule is rounding to 2 decimal places 8I have set 2 decimals in ecart) after added the values are not the same as if I would add both numbers (as they are a 3 decimal values) and round that to 2 decimals.
If i set 3 decimal places everything is ok except in eCart 4.5.2 shopping cart everything is on 3 places. What I need is that internal calculations would be done using 3 decimal places and the result would then be in shopping cart rounded to 2 decimal places, then the values would be correct.
is that possible, even with a "hack" in the code?
ASP here :-)
Jernej
you can use the ASP round() function.
the round function takes 2 arguments, the number to round and number of decimal places.
in the context of displaying an eCart price:
<%=WA_eCart_DisplayMoney(BlueSkyMusic, WA_eCart_DisplayInfo(BlueSkyMusic, "Price"))%>
using the round function would look like:
<%=WA_eCart_DisplayMoney(BlueSkyMusic, round(WA_eCart_DisplayInfo(BlueSkyMusic, "Price"), 2))%>
jernej
Yes I know I can use round, but then I have to change every money display I drop from binding. I have changed the function Display money and entered 2 as the decimals and used 3 as a global parameter. It works, until I reload GUI then obviously the change dissapear.
Btw: Is round with 2 decimals same as FormatNumber?
There is no way of doing this globally except altering the display money function, but yes, if you edit eCart, you will have to re edit the format number function.
Format number is used to format the display of the number, it will force the number of decimals you tell it to display. This comes into play with round round numbers like 11. if you tell format number to use 2 decimals, it form at 11 as "11.00", whereas round(11, 2) will only return "11". Format number will perform the rounding function though.
jernej
Thanx for the explanation. Out tax rule is 0.085 (8.5%) and I am allways having a hard time to round things. On some occasions I miss 1 cent :-( Because 0.085 is on 3 decimals and we have to show store output in 2 decimals there comes to rounding errors all the time.
Thank you again.
This post has been deleted.
