Character Sets and Collations
Thread begun 3/11/2010 4:15 am by anlanza297228 | Last modified 3/17/2010 3:22 am by Rune Brynestad | 4394 views | 7 replies |
anlanza297228
Hello,
There are data in the results shown in symbols.
And when I insert a new record with ñ, á, é, I see bad data in the table in MySQL.
I realize that is a problem of Character Sets and Collations, but do not see how to fix it.
Attached two pictures.
Thanks for your assistance.
You need to change the character set on the table.
To do this, you will need to use a GUI tool for managing your MySQL database. It can be done using myPHPAdmin, or a tool like SequalPro. I am including a screen shot showing how to modify the encoding in SequalPro.
anlanza297228
I use phpMyAdmin.
I have configured for the database and table utf8_general_ci
I tried other character Sets, and still have the same problem.
What character Sets should I use?
I usually use the default latin1_swedish_ci character set and do not have a problem.
Miguel
check your pages that each contain for utf-8 the correct charset
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
charset=UTF-8
anlanza297228
If you found that PHP documents are generated DataAssist charset=utf-8.
And my database and table are in utf8_general_ci.
What was left was the default when you install version 3.2.0.1 of phpMyAdmin.
I have not run into a problem using UTF-8 php pages and the latin1_swedish_ci character set in MySQL
Rune Brynestad
If you have special characters in your language like ñ, á, é or æ, ø, å it's safest to use utf-8 all over.
Here's a setup that works for me:
In your PHP page, use utf-8 as your charset like this:
In your MySQL database:
Use utf8 -- UTF-8 Unicode as your Character set and utf8_yourlanguage here_ci as your Collation
In your connection string:
Add this line at the end of your connection string: mysql_query ('SET NAMES `utf8`');
Hope that helps.
Regards
Rune
