Repeating Tables Not Showing any data
Thread begun 3/10/2010 12:52 pm by dinohorn397192 | Last modified 3/11/2010 9:59 am by dinohorn397192 | 2237 views | 3 replies |
dinohorn397192
I have created my recordset successfully.
I have created my repeating table successfully.
But I could never get any information to show up. When I tested my recordset I could see all the data. I have no idea what's going on.
<?php require_once('Connections/pawtabs_db.php'); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$maxRows_pawtabs = 36;
$pageNum_pawtabs = 0;
if (isset($_GET['pageNum_pawtabs'])) {
$pageNum_pawtabs = $_GET['pageNum_pawtabs'];
$startRow_pawtabs = $pageNum_pawtabs * $maxRows_pawtabs;
$colname_pawtabs = "-1";
if (isset($_SESSION['UserID'])) {
$colname_pawtabs = (get_magic_quotes_gpc()) ? $_SESSION['UserID'] : addslashes($_SESSION['UserID']);
mysql_select_db($database_pawtabs_db, $pawtabs_db);
$query_pawtabs = sprintf("SELECT * FROM paws WHERE UsersId = %s", GetSQLValueString($colname_pawtabs, "int"));
$query_limit_pawtabs = sprintf("%s LIMIT %d, %d", $query_pawtabs, $startRow_pawtabs, $maxRows_pawtabs);
$pawtabs = mysql_query($query_limit_pawtabs, $pawtabs_db) or die(mysql_error());
$row_pawtabs = mysql_fetch_assoc($pawtabs);
if (isset($_GET['totalRows_pawtabs'])) {
$totalRows_pawtabs = $_GET['totalRows_pawtabs'];
} else {
$all_pawtabs = mysql_query($query_pawtabs);
$totalRows_pawtabs = mysql_num_rows($all_pawtabs);
$totalPages_pawtabs = ceil($totalRows_pawtabs/$maxRows_pawtabs)-1;
// RepeatSelectionCounter_1 Initialization
$RepeatSelectionCounter_1 = 0;
$RepeatSelectionCounterBasedLooping_1 = false;
$RepeatSelectionCounter_1_Iterations = "3";
<head></head>
<body>
<table>
<?php do { ?>
<tr>
// RepeatSelectionCounter_1 Begin Loop
$RepeatSelectionCounter_1_IterationsRemaining = $RepeatSelectionCounter_1_Iterations;
while($RepeatSelectionCounter_1_IterationsRemaining--){
if($RepeatSelectionCounterBasedLooping_1 || $row_pawtabs){
<td>&nbsp;</td>
} // RepeatSelectionCounter_1 Begin Alternate Content
else{
<td>&nbsp;</td>
<?php } // RepeatSelectionCounter_1 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_1 && $RepeatSelectionCounter_1_IterationsRemaining != 0){
if(!$row_pawtabs && $RepeatSelectionCounter_1_Iterations == -1){$RepeatSelectionCounter_1_IterationsRemaining = 0;}
$RepeatSelectionCounter_1++;
} // RepeatSelectionCounter_1 End Loop
</tr>
<?php } while ($row_pawtabs = mysql_fetch_assoc($pawtabs)); ?>
</table>
</body>
mysql_free_result($pawtabs);
dinohorn397192
My Output is a white screen
after adding the repeating table to the page, you need to populate the tabel cell with the data you wish to display.
In design view, place you cursor in the main tabel cell, and add any text or dynamic data bindings you wish to display.
dinohorn397192
Got it, thanks!
