Error message in new version
Thread begun 3/10/2010 12:34 pm by web364946 | Last modified 3/12/2010 4:05 pm by Jason Byrnes | 2840 views | 3 replies |
web364946
I have downloaded the latest version of Power CMS, and have replaced the files as adviced.
When updating the site, I now get errors I didn´t get prior to this. I can update text file, but when I try to add images, I get the following error after trying to browse on the server:
"There are errors in your configuration or server. If the messages below describe missing variables, please check the supplied configuration.php.dist for notes on their usage.
KFM does not work if you have safe_mode enabled. This is not a bug - please see PHP.net's safe_mode page for details"
I have uploaded the files exactly as they were when I downloaded them from your site. I have updated the settings in the globals file so they are exactly the same as they were.
Please help asap - what do I need to do to get this to work? What is KFM??
KFM is the new advanced file manager that was implemented in html editor.
From the error, it sounds like you host has configured the server to run in safe mode. KFM is not compatible with servers running in safe mode.
you can disabel the KFM by editing the following two files:
HTMLEditor/custom/contents_insert_ContentValue1.js
HTMLEditor/custom/contents_update_ContentValue1.js
look for the following line:
if (true) {FCKConfig.Plugins.Add('kfm');}
and change it to:
if (false) {FCKConfig.Plugins.Add('kfm');}
web364946
thanks, that seems to have taken care of that issue - now I have another problem, however.
When I try to add an image, I just get that red cross appearing, not the image. When trying to upload the image to the server, I get the message that the upload was successful but no image appears.
I realise that there is probably a problem with my settings but I have tried every combination I can think of in my globals file, and it still doesn´t work.
These are my current settings:
$WAGLOBAL_Site_Name = "Studio N Admin" ;
$WAGLOBAL_localRoot = "/CMS/"; //relative path to your PowerCMS files on your local testing server.
$WAGLOBAL_remoteRoot = "/CMS/"; //relative path to your PowerCMS files on your remote server.
// Admin Settings
$WAGLOBAL_Admin_UserName = "user" ;
$WAGLOBAL_Admin_Password = "pw" ;
The CMS files are located in the folder "CMS", located in the root folder "studio-n.se". The folder "files" have been created in the "CMS" folder, but no images appear here.
The URL shows "/CMS100/files/adaire.jpg". When right-clicking on the red cross I get the properties " http://www.studio-n.se/CMS100/files/adaire.jpg" for the image; no image is available here however.
Are there anywhere else I need to change my settings?? What else do I need to do?
login.php
