Cannot Relocate a site
Thread begun 3/10/2010 11:41 am by mja394004 | Last modified 3/16/2010 4:03 pm by Jimmy Wu | 1999 views | 3 replies |
mja394004
We installed WA PowerStore on our test IIs server and everything was working fine.
We moved everything to a production IIs server and received a http 500 Internal Server Error.
We have obviously forgotten to change a setting, but we cannot locate it.
Does anyone know what changes need to be revised for a relocation?
Jimmy Wu
An easy way to check if there's some server setting that's needed and is different is to upload the default PowerStore 3 files to a different directory and use the Install Wizard to check if there's any errors.
Also make sure you check the connections file to verify that it is connecting to the database the correct way for the live server.
mja394004
Can not relocate a site
Problem solved. Thank you
Jimmy Wu
Great to hear it. If you run into any additional issues, feel free to open a new thread.
