cart.php preview on local server
Thread begun 3/10/2010 9:16 am by art391139 | Last modified 3/12/2010 4:06 pm by Jason Byrnes | 7888 views | 24 replies |
art391139
I have installed Ecart 5. When I click on the ecart cart button it redirects me to the correct page cart.php. However the page is blank.
when a page displays blank, it means a php error is occurring, but error reporting is turned of in the php.ini file.
to enable error reporting, add the following code at line 1 of your page:
error_reporting
(E_ALL);
art391139
error message
What does this mean?
//WA eCart Include require_once("../WA_eCart/store1_PHP.php"); ?>
Notice: Undefined variable: store1 in /Applications/MAMP/htdocs/Pages/c01.php on line 10
Fatal error: Call to a member function GetContent() on a non-object in /Applications/MAMP/htdocs/Pages/c01.php on line 10
this error usually occurs if the Cart object and the Database connection have been with the same name.
You must use unique names for you application objects like connection, recordset or cart object.
art391139
reply
The names are not the same
please send a copy of your page so I can examine the code.
art391139
File attached
the file you have sent is not the same as the one generating the error message.
The error massage is saying:
however line 10 in the file you sent is
there is no variable named "store1" on line 10.
I need to see the copy of the file that is causing the error you are reporting.
art391139
It was the same file without this code in front
error_reporting(E_ALL);
I attached it again with the code
right, so when you added in this code:
error_reporting
(E_ALL);
you deleted the next opening php tag. Line 1 - 7:
error_reporting
(E_ALL);
//WA eCart Include
should be:
error_reporting
(E_ALL);
//WA eCart Include
