shipping variables
Thread begun 3/09/2010 8:21 pm by JBWebWorks | Last modified 3/10/2010 6:51 pm by Eric Mittman | 3334 views | 3 replies |
JBWebWorks
shipping variables
not sure how to write shipping rules that have several variables.
three item types
1
2
3
owner wants these shipping variables
item 1 and item 3
qty 1-3 shipping is $6.50
4 and over shipping is $10.70
item 2
qty 1 shipping is $6.50
2 and over shipping is $10.70
Any combination of item 1, 2 or 3
shipping is $10.70
thanks
Jim B
You can set these shipping charge rules directly in the cart object. There is no need for any variables, you can write the rules like how you have them here.
For the first example you would craft the rule like this:
Presence of an item in the cart, if item 1 exists in the cart
AND quantity of a specific item in the cart, if the quantity of item 1 in the cart is <= 3
OR Presence of an item in the cart, if item 3 exists in the cart
AND quantity of a specific item in the cart, if the quantity of item 3 in the cart is <= 3
The charge would be a flat rate of 6.50. I'm including a screen shot of this so you have a visual reference as well. You should be able to craft the other charge rules in a similar fashion.
JBWebWorks
thanks Eric
that helped me a lot.
one problem i am having is different shipping rules overlapping.
for instance i have the rule for item 1 and 3 qty being <= 3 shipping is $6.50
another rule is item 2 qty = 1 shipping is $6.50
another rule is qty of unique items >= 2 shipping is $10.70
so if the cart has 1 of item 1 shipping is $6.50 and cart also has 1 of item 2 shipping is $6.50 and the combination of item 1 and 2 has shipping of $10.70, so total shipping is $23.70.
You will need to decide what shipping rule will take precedence, then for the other shipping rules you can check on the opposite of the conditions for the main rule.
So if you wanted the first rule in your scenario to take precedence you would need to alter the other two rules like this:
In this rule you would need to add the opposite condition of the first rule, so in here you would add a condition that says 'and if item 1 or item 3 does not exist in the cart'. You would do the same in third rule, you would need to add a condition to make sure that items 1 and 3 are not in the cart.
The charge rules are very flexible and you can account for many situations, you just need to determine in advance how exactly you would like the charges to occur then based on this configure them to fit your scenario.
