Sample Upload Not Working
Thread begun 3/09/2010 3:17 pm by dinohorn397192 | Last modified 3/15/2010 3:54 pm by Jimmy Wu | 2202 views | 3 replies |
dinohorn397192
blah, it worked using data assist. My question now is...
The image is getting uploaded in the correct directory. But only this field's data isn't getting inserted into the database table. All other fields are put in correctly. I have this field as "varchar(50)" . Is that correct?
Jimmy Wu
Is the DataAssist insert behavior applied after the upload? Digital File Pro will not automatically insert into the database. You will have to use DataAssist to insert the filename at the same time you insert any other information. Using varchar(50) should be fine as long as you're not going to be uploading filenames that are close to that many characters (including the extension).
dinohorn397192
Thanks, that solved it
Jimmy Wu
Great to hear it. If you run into any additional issues feel free to open a new thread.
