DataAssist, error in your SQL syntax.
Thread begun 3/09/2010 5:45 am by anlanza297228 | Last modified 3/11/2010 3:59 am by anlanza297228 | 3049 views | 2 replies |
anlanza297228
Hello,
I get an error message when I go to Update or Insert a new record in my MySQL database.
The message is as follows:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '45123333undefined, `puesto` = undefinedSecretario Generalundefined WHERE `nombre' at line 1
My table is called usuarios and has 3 columns: nombre, direccion and puesto.
Thanks for your assistance.
looking at the error it looks like the data types are not set properly.
Double click the Update Record and Insert Record server behaviors, and make sure the data types for each column are set then click OK to regenerate the code.
anlanza297228
Thank you.
OK, thank you very much I could solve.
I have another query, but for another post.
Thank you.
