eCart
Thread begun 3/09/2010 12:18 am by david331670 | Last modified 3/09/2010 4:11 pm by Jason Byrnes | 2431 views | 3 replies |
david331670
eCart
I'm stumped.
I have created a repeating region with a list of products from a data base with the add to cart button.
If I select one of the items down the list eg. 4th from the list, click add to cart it works adding the correct selection, thumbnail, description and to the cart.
Instead of add to cart button I would like a link to a separate page that will populate the page from the ItemID I have created a page link mycartpage.php?ItemID=4 where my page is set up with an add to cart function. It works no problem.
I would like to pick up the ItemID from the first mentioned repeating region, eg. itemID=4
I assume there would be a php script as there is in the add to cart button.
How can I pass the appropriate itemID to "mycartpage.php" to populate the cart page.
eg only <?php echo $row_rsComp["ItemID"]; ?>
I would appreciate your help
Thank you
David
set the link to pass the id value from the recordset:
mycartpage.php?ItemID=<?php echo $row_rsComp["ItemID"]; ?>
On the mycartpage.php page, create a recodrset that will filter the ItemID column of the products table on the ItemID querystring variabel.
Then add the Add to Cart server behavior. On the server behviaors panel, click the plus button and select eCart -> Add to Cart -> Add to Cart. select before page load or recordset not empty for the trigger. On the bindings tab, bind the Cart Columns to the recordset columns.
david331670
eCart
Thank you
I was so close, a few more trial and errors' might have seen me thru.
Never mind, thanks again.
no worries.
