Navigation problem
Thread begun 3/08/2010 11:55 am by schermak267582 | Last modified 3/09/2010 11:37 pm by schermak267582 | 4925 views | 8 replies |
schermak267582
Navigation problem
I used Siteassist professionnal
If you open the following page it appears ok with firefox but the menu
doesn't display properly using internet explorer.
e-crpe.com
Can you please tell me what I can do to solve this problem.
Many thanks
Jimmy Wu
It seems that you are running into the same issue as this user:
showthread.php?t=1159
schermak267582
Navigation problem
Thank's very much Jimmy.
I'llhave a look this eveniing.
schermak267582
It looks like the line is in the place stated.
I have tried to remove it.
I end up with the same problem.
My menu does not appear correctly in IE
Thanks for your help.
<!--<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd"> -->
<head>
<meta name="verify-v1" content="rdappPBy492iK8Uz/aulEwK+j8I/6A9vSmAKgbqFtn0=" />
<title>Accueil</title>
<style type="text/css" media="all">
neilo
Try removing that first remarked out Doctype declaration, see if that does it.
schermak267582
Thanks neilo for your answer.
I have uncommented the first line and it works now either in IE or Firefox
neilo
Cool schermak, glad it's working. The only thing I would query is why there are two DOCTYPE declaration lines at the top of the page, there should only really be one.
It might be worth completely removing the one that doesn't match the DOCTYPE of the rest of your site's pages.
Jimmy Wu
As Neilo pointed out, having two doctype tags on your page is not standard. You should figure out which one works for your site and remove the other one. Make sure you don't leave any whitespace (ie, an empty line) when you remove the unnecessary doctype tag.
schermak267582
Navigation probem
Many thanks to both of you.
I'll remove as you pointed out one of the lines.
