Adding Links to power gallery thumbs
Thread begun 3/06/2010 1:41 pm by Jay Core Global Media | Last modified 3/08/2010 2:32 pm by Justin Nemeth | 1310 views | 1 replies |
I would Like to a add links to powerstore3 products when a thumbnail is clicked on in powergallery ribbon light box, but i do not want the lightbox, I am trying to create something similiar to apples slider itunes/
Justin Nemeth
This will require some custom coding, but here is the general idea you could do. Open up the index.php for your gallery and around line 59 you will see a for loop. This loop is what prints out all the thumbnails. You can see it wraps each thumbnail in an <a> tag. To prevent the lighbox, you would remove the rel attribute. Then you would have to come up with a way to set the href for each image.
This is where the custom part comes in for you to implement. You could for instance put the url in the description field for each image, then use that as the href in the a tag. Something along those lines should get you started.
-justin
