CSS menues good for iPhone
Thread begun 3/05/2010 12:23 pm by rick178787 | Last modified 3/05/2010 5:08 pm by Jimmy Wu | 2148 views | 3 replies |
rick178787
anybody found any good css menu solutions that display well on iphone?
Jimmy Wu
I believe that the iPhone browser is very similar to Safari. If it works in Safari, it most likely will work on the iPhone as well. After testing one of the Menu Writer menus on the iPhone it works.
rick178787
Sorry, I should have been more specific. I've discovered that any number of CSS menus will work well enough in modern browsers AND the iPhone, as long as you have code in your <head> to id the iPhone.
What I was looking for was CSS parameters for the menu. I figure somebody had fiddled around with the tedious business of CSS parameters and found some width and height combinations that look good on both the iPhone and the desktop or that accordion to fit font and string length.
I've also got some AJAX menus that will work (anything but Flash, actually).
Jimmy Wu
Ah, I understand what you're looking for now. I haven't actually played around with creating a menu that will look good in both the portable browsers and on normal browsers. It would have to depend on the menu contents as well I believe.
