Internal Server Error
Thread begun 3/04/2010 4:15 pm by westmorelandgraphics311771 | Last modified 3/08/2010 3:28 pm by Jimmy Wu | 4253 views | 7 replies |
I keep getting a internal server error when I try to access my store online. I'm using PowerStore200. My hosting site uses cPanel X. I've created and checked the database and the login info. Since I'm new to this, I'm not sure what the problem is and what to try next. This is the error I am getting:
[03-Mar-2010 15:47:52] PHP Warning: chmod() [<a href='plugins/function.chmod'>function.chmod</a>]: No such file or directory in /home/denwest/public_html/store/prepare_removal.php on line 110
Jimmy Wu
can you send me a link to your page where I can take a look at this error?
website link
www.oceanbeachdreamin.com
click on: shop ocean beach
It should take you to the store in the subdomain: www.store.oceanbeachdreamin.com/
Were you able to take a look at this? I haven't heard back from anyone.
Denise
Jimmy Wu
The error you reported at the end of your first post was from the error log?
What is the line of code that is referred to in the error?
It seems that it may be caused by a permissions issue. There may be insufficient privileges to run chmod. If you have a hosting provider or system administrator you should contact them to check that for you.
Hi, Jimmy,
I copied and pasted from the error log. I don't know what that line of code is or how to find out. I am very new to this and don't understand about all the lines of code and where to find them. I don't know what you mean by run chmod. I set up my database through cPanel X with full permissions. If you can help me by telling me where to find the info you need, I will track it down and get back to you. Thanks.
Hi, Jimmy,
I just finished talking to my hosting provider. They reset the permissions and I am able to get in and navigate around, but am unable to get to the admin site. The home page url is:
index.php
When I type admin after store, I get an Error 404 - Page Not Found. If I type admin at the end of this string, I get a funky home page without the css or images. Can you help with this?
Jimmy Wu
Your server is case sensitive, so you have to type in the url like this:
Admin
Make sure the 'A' in Admin is capitalized.
