DataAssist Dynamic Checkboxes Search
Thread begun 3/04/2010 12:15 pm by vito374252 | Last modified 3/05/2010 9:04 pm by anonymous | 1772 views | 2 replies |
vito374252
Hello,
I built the search using DataAssist Search Wizard. The form is made of checkboxes and it all works well.
The next step that I would like to take is to make the search form dynamic. At the moment the values of the checkboxes are taken out of an MySQL table and each checkbox category is populated from its own recordset.
What I would like to achieve is that when one checkbox is selected all others change automatically to match the selected checkbox. It would sort of be a filtered search.
For example:
When "Gaming" checkbox is selected all other checkboxes values would need to change to match this selection. For example manufacturer would change to Dell, MSI. Display size to 17, CPU model to Intel Core 2 Duo and so on.
Here is the link notebooks-search.php and scripts attached.
Thanks!
This is not a feature that is supported in DataAssist or any of our other tools and would require a custom solution. From what you have described you would need to have some recordsets on the page and use some js to switch out the display based on the user selection. The idea is similar to what Dynamic Dropdowns does, but takes it quite a bit further. If you have Dynamic Dropdowns you might be able to look at the code there to get an idea for how this type of thing can be done.
anonymous
I have actually create a similar search application. The best way to accomplish this would be to use an AJAX script to add variables, based on selection criteria from the check boxes, to the URL, such as this: www.mypage.com?computer=dell&othervar=anothervalue&nextvar=athirdvalue
Then, just as Eric stated, you use recordsets where you would filter the recordset based on the appropraite column containing the data in the URL variables.
such as: SELECT * FROM table WHERE computer = '$_GET['computer'] AND othervarcolumn = '$_GET['otherval']
You may need several record sets to get it done to exact spec as you want. And you may also need a lot of "if" statements.
Regards,
Brian
