UserID added to Product Update
Thread began 3/04/2010 10:26 am by jed193733 | Last modified 3/15/2010 4:09 pm by Eric Mittman | 2479 views | 11 replies |
jed193733
I'm using this store foundation for something a bit different than an online store. I need to add the userID to the database when an update or addition is made.
I've been looking around the ProductsInsert.php and am confused with $_Post from the lines 157-8. I've been able to add the column in the database and create my own form to update the database, but would like to use the WA form in place.
Am I looking at the right lines? Can you give me the proper syntax to $_Post the userID to the Products table? I hope you can help me this. Thanks.
How are you getting the value for the user id currently? By default the only user id that would be available to you in the admin is the id for the administrator user. To get the id for a regular site user you would need to use the session variable for their id or something like this. On the front end of the site the id is held in a session variable when a user logs in. So on any of those pages you can make reference to this users id whenever they are logged in.
Please post back and describe a little more about the specifics and what you are trying to accomplish and we will help you out with whatever we can.
jed193733
UserID
Yes, I was thinking I could use the session UserID. I've been able to echo it on the update page after logging in so I thought I that would work. I was thinking read the session UserID and post it in the new column userID column in the products table.
Trying to keep it simple right now.
Complex version later - tracking the edits like content management tracking section.
If you can see the userID session var on the update page already then you just need to bind it to your userID column that you have for that table. It sounds like you are well on the way, let us know if you have any further questions about this or any other part.
jed193733
Binding...
I'm having some trouble understanding the sql insert statement.
From the Products_Insert.php I've changed the following lines:
Line 157:....ProductUnlimited|MarkerUserID";
Line 158:......((isset($_POST["ProductUnilimited"]))?$_POST["ProductUnilimited"]:"") ."|" . "".($_SESSION['UserID']) ."";
Line 159:...NULL|none,1,0|none,1,0";
This is all I've changed and it's not updating - am I working on the right lines? what's wrong with my syntax.
Thanks in advance...
This is a change that may be a little difficult to make manually since the code you are editing was created with DataAssist. If you can post back with the page that contains the updated code in it I can take a look at things and let you know what I think. I should be able to help you get this worked out.
Just for clarification, the session variable $_SESSION['UserID'] is set when you are on this update page correct?
jed193733
Yes the userID is set - I test that by displaying it on the bottom of the page - line: 742
new Insert file attached. Thanks Eric. If you want to register yourself I'll be happy to give you access to the site. keywesthistoricmarkertour.org/3
Markers_Insert.zip
Thanks for getting this page to me. The updated insert server behavior has been edited correctly and you have setup the insert parameters without error. The problem is that this code is never being executed. You have the action of the form still going to the product insert page. You should either leave it blank or set it to this Markers insert page.
I did a test of your page with a copy of my products table and can confirm that the userID is making it's way into the table.
jed193733
Sorry .....
Thanks Eric... I'm getting this error when I change the action to Markers_Insert.php.
Unknown column 'MarkerUserID' in 'field list'
Feeling a little dumb here.....thanks for your patience....
This error you are getting means that it cannot identify the column named MarkerUserID in your table. When I tested this I had to add this column to my table in order for the insert to work properly. Once I did this and adjusted the action it inserted without issue. I probably should have caught this earlier but I was assuming that the column already existed.
