How do I convert UNIX timestamps to the date format d.m.Y inside a query
Thread begun 3/03/2010 7:51 am by Rune Brynestad | Last modified 3/04/2010 10:03 am by Dave Buchholz | 6276 views | 6 replies |
Rune Brynestad
I am trying to write a query but I have run into a snag. I am trying to convert an UNIX timestamp to something PHP would like.
For example, I have this query.
SELECT Name, FROM_UNIXTIME(UNIX_TIMESTAMP(Date_of_birth),'%d.%m.%Y') As Date_of_Birth FROM Test
This should convert to "11.08.1964" however it converts to 01.01.1970
How do I convert UNIX timestamps to the date format d.m.Y inside a query?
I'm attaching my sample files and database.
Regards
Rune
Jimmy Wu
Try using the Dateadd call instead and see if that works for you. Here's a reference so you can take a look at what this function does:
ms186819.aspx
Dave BuchholzBeta Tester
Firstly the value you have in your db (INSERT INTO `Test` VALUES ('1', 'Rune Brynestad', '-170125200')) is not a unix timestamp
When you have corrected that the correct way to convert this would be:
SELECT Name, FROM_UNIXTIME(Date_of_birth,'%d.%m.%Y') As DOB FROM Test
Tip: Always give your alias a unique name
Rune Brynestad
Have done some more testing. From what I see, MySQL's FROM_UNIXTIME() function does not support negative epoch timestamps (just as the inverse function UNIX_TIMESTAMP() does not either).
It looks like I could use the DATE_ADD function
SELECT Name, DATE_ADD('1970-01-01', INTERVAL Date_of_birth second) As DOB FROM Test
gives me 1964-08-11 00:00:00 which is correct.
What I need now is a way to format this date the way we use it in Norway which is 11.08.1964 or dd.mm.yyyy
It still have to be done inside the query. Could it be done ?
Regards
Rune
Try this:
SELECT Name, DATE_FORMAT(DATE_ADD(FROM_UNIXTIME(0), INTERVAL Date_of_birth SECOND), '%d.%m.%Y') As DOB FROM Test
Rune Brynestad
It works like a dream.
Thanks a lot Dave.
Regards
Rune
No worries, it was an interesting question and I learnt something in the process of solving it so we both gained something.
