How to create a rule "do not show if blank"
Thread begun 3/02/2010 10:14 pm by elewis93815 | Last modified 3/11/2010 11:50 am by Jason Byrnes | 3911 views | 6 replies |
elewis93815
We have created a search that in some cases will have fields that are null in our table. We would like the results page to not show the blank fields as spaces. If we have a search for a person that has a "name, address and phone" and the next has just "name and phone" we would like the space for "address" to not show. I assume that we should create a rule somewhere on this page that says "don't show if null" or along those lines. We are fairly new to this function so any assistance would be greatly appreciated.
John LangerBeta Tester
This is fairly easy using a bit of PHP. Below is an example of NOT showing a table row if a column is empty.
If want to do the opposite (Only show it if it has a value) then change !="" to ==""
The first is saying show if the column is NOT empty (it HAS a value), the second is Show if the column IS empty (It DOESN'T have a value). This is useful for displaying a "No results found" message.
<?php if ($row_rsRecordset['address']!=""){ ?>
<tr>
<th>Address:</th>
<td><?php echo $row_rsRecordset['address']; ?></td>
</tr>
<?php ?>
You may also want to modify the if statement to check for null in addition to a blank record:
<?php if (($row_rsRecordset['address'] != "") && ($row_rsRecordset['address'] != NULL)){ ?>
elewis93815
Hi, we are still struggling with this purposed solution we would greatly appreciate it if someone from your support team would contact us as soon as possible. We are on a deadline and need to resolve this today please. We hope that this is a simple task, however we are not clear on the direction. The website url is: www.themaverickinstitute.com
OUR GOAL: We would like to get rid of the space between records that have no data, but have a data field (& remove the blue lines)
Our contact info is: 952.583.5616
Thank you very much for your assistance!!!
Jackie or Erick
E.L. Lewis Enterprises Incorporated
did you see my previous reply about adding a check for null to the if statement?
if it is not working, can you send a copy of your page so I can examine the code?
elewis93815
DataAssist
We did read your thread, however would appreciate some enlightening to where this code belongs, we looked at our code (we're novices) and do not see where to alter or change what the WA plugin has created.
I've attached the files for your review,
Thank you very much!
Erick
exactly where the code goes depends on where you want to use it.
lets take the detail page as an example.
the code to display the First name is:
<tr>
          <th class="WADADataTableHeader">FirstName:</th>
          <td class="WADADataTableCell"><?php echo($row_WADArick['FirstName']); ?></td>
        </tr>
to suppress the first name row from being created if the first name is empty or null, you add the if statement around it:
<?php if(($row_WADArick['FirstName'] != "" ) && ($row_WADArick['FirstName'] != NULL)) { ?><tr>
        </tr><?php ?>
or if you wish to suppress the last name change:
<tr>
          <th class="WADADataTableHeader">LastName:</th>
          <td class="WADADataTableCell"><?php echo($row_WADArick['LastName']); ?></td>
        </tr>
<?php if(($row_WADArick['LastName'] != "" ) && ($row_WADArick['LastName'] != NULL)) { ?><tr>
        </tr><?php ?>
