fixed footer problems ...continued
Thread begun 3/02/2010 11:03 am by CraigR | Last modified 3/02/2010 10:17 pm by CraigR | 2361 views | 2 replies |
CraigRBeta Tester
further to my last problem, i still haven't sorted this one out.
showthread.php?t=10715
i made an amendment to the #fixedFullWidthFooter div, so it is taller than it was.
i seem to remember that in the original css, the top margin had a negative value, - is this supposed to be the same as the height of the div ?
when i don't have a top margin set, i can see all of the page content, at both resolutions, but the footer does not anchor to the bottom of the page but below it.
when i set the top margin to a negative value, the bottom of my content div is cut off.
i seem to be going round in circles.
i would appreciate some tuition.
(i have FF and use firebug but struggle to debug this)
regards
test3.stonepits.com/
Justin Nemeth
Looks like a margin-top: -192px; on the fixedFullWidthFooter and a padding-bottom: 192px; on the contentWrapper will do the trick. You basically negative margin the footer equal to the height, then add some bottom padding on the contentWrapper to make sure it doesn't overlap.
-justin
CraigRBeta Tester
that's it!
thanks Justin.
that's the fix and the little nugget of info I needed.
brilliant
