Form isn't sending files to database
Thread begun 3/02/2010 10:14 am by mrobben375515 | Last modified 3/05/2010 2:55 pm by Jason Byrnes | 3640 views | 12 replies |
mrobben375515
I have a registration form on the index page of www.1to1marketing-llc.com that I would like to have submit the info into our database. However, when I test it is says that it is sending the request but the data never gets into the database. Do I have something set up wrong?
I set up 2 server behaviors...WA Upload Files and Insert Record.
can you send a copy of the page so I can examine the code please.
mrobben375515
I attached the file. It's index.php
this is being caused by a bug I have just identified in form builder.
you have form elements that have a comma in the name, for example:
Registration_group_I_herby_certify_that_the_photo_I_am_about_to_submit_is_my_original_work_and_has_never_been_copyrighted_or,_if_copyrighted,_that_I_am_the_sole_copyright_owner_I_am_entering_this_photo_as_a_honest_and_true_effort_of_my_personal_creativity_and_unique_vision,_and_I_understand_that_it_will_be_published_on_the_Internet_as_my_original_work
the name of the form element is generated from the label you apply to it in Form builder. If you use commas in the form element label, they will also be applied to the name. Commas in the form element name are not legal.
For now, please don't use commas in the element labels. I have logged this as a bug in our bug base to have it fixed in a future update.
mrobben375515
Thanks for the response. It's still not working right however. I made the changes in the form, went in to the insert record server behavior and updated it to the new label names for those 2 categories that had commas. Tested it online, and it didn't submit the information still. It's supposed to insert the info into the database and if that's successful take the user to the gallery.php page. It doesn't do either one. We also have a WA Upload Files server behavior that takes the images and makes them different sizes and when we get rid of that everything works fine. The trigger for both behaviors is the form submit button, could that be the problem?
mrobben375515
here's the index.php file again
It could be that there is an error occurring in the file upload.
Add the following code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
post back with the text of any errors that are returned.
mrobben375515
This is what came up....
Parse error: syntax error, unexpected ')' in /home/content/o/n/e/onetoonemktg/html/index.php on line 1
My apologies, there was a typo in the code, the correct code is:
error_reporting
(E_ALL);
mrobben375515
no problem, this is what came up this time...
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/o/n/e/onetoonemktg/html/index.php:5) in /home/content/o/n/e/onetoonemktg/html/WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php on line 3
