eCart
Thread begun 3/01/2010 11:40 pm by david331670 | Last modified 3/05/2010 1:02 pm by Eric Mittman | 3070 views | 5 replies |
david331670
eCart
Help
I am using 1 shopping cart page for multiple "sales pages"
How can I get the user to go back to the page they were on when they continue shopping or clear items from the cart. I got the return page for one page as designated in the clear button . I need the go back button on the browser, but for the shopping cart.
Any solutions??
David
In the continue shopping server behavior you can check the box to go to the previous URL, this will take the user to the last page they were on. The clear cart is different, it does not have this option. You can make it work like the continue shopping though by altering the clear cart code on the page to be like this:
// WA eCart Clear Cart
if (isset($_POST["eCart1_Clear_100"]) || isset($_POST["eCart1_Clear_100_x"]))     {
$eCart1->ClearCart();
$Redirect_redirStr="";
  if (
true && isset($_SESSION['WAEC_ContinueRedirect'])) {
$Redirect_redirStr=siteToPageRel($_SESSION['WAEC_ContinueRedirect']);
  if (
$Redirect_redirStr != "")     {
$eCart1->redirStr $Redirect_redirStr;
$eCart1->cartAction "ClearCart";
This is the for eCart1, you would need to update this with the name of your cart.
david331670
eCart
Eric
Thank you
You're welcome, let us know if you have any other questions or if you encounter any issues.
david331670
eCart
Eric
I have tried to use the php supplied.
I cut and pasted the php supplied and changed "ecart1" name where ever it was in the supplied script to my cart name. This I copied from the Continue button script.
The page will not render in my browser at all.
I noticed that the script was almost the same as the "continue shopping" php
should??
($_SESSION['WAEC_ContinueRedirect']))*read ($_SESSION['WAEC_MyCartNameRedirect']))
I did change this but it still would not render.*
Regards
David
All I did to make this update was take this code from the continue shopping server behavior:
if (true && isset($_SESSION['WAEC_ContinueRedirect'])) {
and add it into the clear cart code. If you are having trouble getting my code to work you can just take from your own code, if your continue shopping button is working for you then this code should work the same.
If you continue to have any troubles with this post back with a copy of your cart display page and I can show you where and what update to make.
