how to set distinct on childlist
Thread began 3/01/2010 1:13 pm by asnw0764437428 | Last modified 3/05/2010 12:33 pm by asnw0764437428 | 1617 views | 3 replies |
asnw0764437428
I have 2 tables setup. Counties (parent) Business categories (child) All works as it should with the dynamic dropdowns except:
Currently the child recordset is set as;
SELECT bizID, bizCategory, cat_id FROM bizconns GROUP BY bizID
The problem I cannot seem to work out is how to set a distinct within the child recordset.
I'm losing my hair on this one!
Please if anyone can point me in the right direction, thanks.
try using this for the SQL instead:
SELECT bizID, bizCategory, cat_id FROM bizconns GROUP BY bizCategory
The GROUP BY clause should be set on the column that you want to return distinct results on.
Dooza
When using GROUP BY you need to select all the columns otherwise you will get an error.
FROM bizconns
GROUP BY bizID, bizCategory, cat_id
The other way of doing this would be to do this:
SELECT DISTINCT bizID, bizCategory, cat_id
FROM bizconns
asnw0764437428
distinct childlist
many thanks dooza. everything is working brilliantly now and my hair is restored.
