MySQL Connection Won't Connect
Thread begun 3/01/2010 11:30 am by webassist2366041 | Last modified 3/02/2010 10:27 am by Eric Mittman | 1330 views | 1 replies |
webassist2366041
Mac OS 10.5.8 and Dreamweaver CS3 with User Registration Solution Pack
I've set up a database and uploaded the empty table.
In Dreamweaver, I opened the "Database" window and opened the "MySQL Connection." I filled out the connection name, used the server's IP address for the "MySQL server," and put in the user name, password, and database name.
When I clicked the button to test it, a window popped up and said, "An unidentified error has occurred."
I tried clicking the "Select" button beside the "Database" field (which I filled out), but it said the same error.
I spoke to tech support at my hosting company. He tested it for firewalls, put in my computer's IP address for access, and allowed universal access, but I still received the same error every time.
I gave him the exact information that I used in the fields (including the IP of the server) and he connected.
A couple of days later, I called my host again. This time, a different tech support guy and his supervisor tried all of the same steps. They confirmed that they could get access, but I still couldn't.
What should I do?
Unfortunately the unidentified error is a problem that occurs from time to time when creating a connection inside of DW. To try and resolve the issue you should make sure to delete your connection from within DW. Next you should clear the cache file for DW with these instructions:
It would also be worth deleting your _mmServerScripts folder from your site root in case there is any bad connection info in there. Once you have done these things try creating the connection again and testing it. When it comes to the db name try entering one in rather than using the select button.
Also, you should confirm with your host that remote access is allowed for connecting with the MySQL db. It is very common to disable remote access and force only local access to the MySQL server. It seems like you host may have it setup for you to access based on what you posted here but it is something else to check.
