Login impossible
Thread began 3/01/2010 3:44 am by alex394211 | Last modified 10/27/2010 7:55 am by Jason Byrnes | 2391 views | 9 replies |
alex394211
Login impossible
Hello, today i wanted to do some changes on my gallery, but unable to login. Was checking once again (in database wa_settings) if i use the right username and password. and yes, i do. But still not able to login. No error appears, nothing. Only the admin login page reloads, that all. What's going on there? Need help urgently.
usually, when log in fails and you are using the correct username and password, it point to a problem with the servers session management.
to test your server to see if sessions are the problem, download the sessionTest.php script from the following message:
showpost.php?p=23826&postcount=2
alex394211
Hi, thank you very much for your response. I've put the test php onto the server. click onto the first link: sessionTest.php?test=test, click on the second link goes back to the main php: sessionTest.php.... something strange is going on there?!
can you post a link to the sessionTest.php page so I can test it?
alex394211
of course: sessionTest.php
login.php
andy95879
Same problem
I am experiencing the same problem, can you provide a solution?
sessionTest.php
in the case of alex394211, the issue was caused by a bad httaccess rule that was causing page redirection before the login could be processed.
If you have any HTACCESS rules configured for your site, please disable them and try again.
andy95879
Bad .htaccess
I've removed my htaccess file and it works! Thank you.
Nice, glad to hear it is working.
