Fatal Error with WA_RandomPassword
Thread begun 2/28/2010 10:40 pm by mora398588 | Last modified 3/01/2010 12:58 pm by mora398588 | 1628 views | 2 replies |
mora398588
After following all of the steps in an online tutorial of yours for sending a forgotten password to a user, I copied all the recommended files to my testing server. When testing the form, I was hit with this error:
Fatal error: Call to undefined function WA_RandomPassword() in C:\xampplite\htdocs\hrconsortium\forgot_pswd.php on line 9
According to the tutorial, I used WA Cookies, DataAssist and SecurityAssist in setting up all the parameters and functions for the form. I have attached a copy of my .php file for your review. Can you provide a solution?
Thank you!
the following code at line 84 - 86:
require_once("WA_SecurityAssist/WA_RandomPassword.php");
needs to be moved to line 6.
mora398588
I will give your suggestion a try. Thank you.
