Additional fields generated by the Wizard
Thread begun 2/28/2010 12:58 pm by donald.dickson338135 | Last modified 3/01/2010 3:28 am by donald.dickson338135 | 1889 views | 2 replies |
Hello - this post actually contains a series of questions some of which have probably been caused by something I did wrong.
The support I have been using to help get me to this stage are the flash videos from the Introduction to Security Assist. I got over the fact that the videos refer to a different table and worked out that visitors can be substituted for users. I am fairly sure that in following the videos on a step by step basis I was able to set up the wizard however the results were unexpected
1 - in that the userLevel field has ended up on the Vistor Registration and Visitor profile pages. (Two jpegs attached)
2 - in that the log in page has two forms (jpeg attached)
3 - in that the log out page has two forms (jpeg attached)
I am not sure what happened to cause these. I can probably just delete the surplus form code on the login and logout pages but I am not sure how to correct the registration and profile pages.
Should I just delete the lot and start again?
Best wishes
Don
Office Guy-172461
You want the userlevel field to be a hidden type. This allows you to process the field normally but keeps the user from seeing the field or modifying it.
One tip. It is far easier to learn how these extensions work if you don't hold on to pages that go astray. Just delete the page and try again. Every time you try something, study the generated code. You will quickly learn what happens with different options. If you keep reusing the same page you can end up with duplicate code that can mess things up and make it hard to figure out.
Concentrate on learning the extension instead of a successful outcome. That way you will understand what's going on instead of just completing a page.
Got it!
Hello and thank you for the reply - I clearly missed a step somewhere in not setting the hidden value -I will go back and start again.
Thank you also for the advise on the learning process. I accept that most of my issues will be down to missed steps and sticky typing.
So now |I know it's OK to delete pages and start again and nothing will "break"
Apprecated your feedback and thank you for your patience.
Best wishes
Don
