data assist costum error or success message
Thread begun 2/27/2010 12:20 pm by randyw2394710 | Last modified 3/09/2010 6:13 pm by Dani Chankhour | 6111 views | 15 replies |
randyw2394710
I would like to have the insert page, check to see if there is allready a specials name before insert into data base. If it does exsists i would like to have a <div> tag appear with that name and say error duplicatate name on the insert page. If it does not exsists go to detail page with <div> tag apear with suuccess specials name has been added.
---------insert page----------------------------------
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $BrowardLimo;
$WA_table = "specials";
$WA_sessionName = "WADA_Insert_specials";
$WA_redirectURL = "specials_Detail.php";
$WA_keepQueryString = false;
$WA_indexField = "id";
$WA_fieldNamesStr = "specialName|createdBy|updatedBy|email|removeOn|comment";
$WA_fieldValuesStr = "".((isset($_POST["specialName"]))?$_POST["specialName"]:"") ."" . "|" . "".((isset($_POST["createdBy"]))?$_POST["createdBy"]:"") ."" . "|" . "".((isset($_POST["updatedBy"]))?$_POST["updatedBy"]:"") ."" . "|" . "".((isset($_POST["email"]))?$_POST["email"]:"") ."" . "|" . "".((isset($_POST["removeOn"]))?$_POST["removeOn"]:"") ."" . "|" . "".((isset($_POST["comment"]))?$_POST["comment"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_connectionDB = $database_BrowardLimo;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
Dani Chankhour
here are the steps:
1. create a record set that filters based on the post value, in your case it is probably the email.
2. then use the Dreamweaver Show Region Server behavior to show the div if the record set is not empty
3. then surround the DataAssist server behavior with the opposite logic, so you wanted if the record set is empty to run the datassist server behavior.
let me know if you have any additional questions.
randyw2394710
fromcapabler
hey there is there any tutorial to do this its little confusing but looks close i will try it
Dani Chankhour
We don't have a tutorial on how to do this, but we can take it one step at a time.
First, try just creating a record set that pulls everything from your special table. Then in the same interface, you could see there is a filter drop down list, select the unique column that you don't want to duplicate and then use form variable from the second drop down list and then type the input field name.
let me know once you have the record set created.
randyw2394710
ok i have created a record set for database i selected all columns the filter specialName = (for the = part what do i use i thought equal maybe contains does not work for both) form variable specialName
ok i tested it and still intered the duplicate entry maybe not done yet
Dani Chankhour
You should select "=". Now for the second step. Select the div that you want to show, and then in the Server Behaviors Panel (Window -> Server Behaviors) click the + button and select show region -> show if record set is not empty.
This will make it so that when the record set is not empty it will show the div.
randyw2394710
ok how will this stop the insert into the database if allready exists
randyw2394710
ok i got the div to appear when inserted how do i stop an entry
specials_Insert.php
here is example now i want to check if there is duplicate and on insert page show div with error and name allready exists thanks
Dani Chankhour
Can you send me your insert page in a zip file and i will tell you what you need to change exactly.
Btw, i just did a test on your site by inserting a test entry twice but i did not get the div to show. I will look into that once you send me your file.
randyw2394710
Originally Said By: Dani Chankhour
the div appears on the detail page i have attached both insert and detail thanks for help
