Issue insert record with upload file field.
Thread begun 2/26/2010 9:35 am by account134484 | Last modified 3/03/2010 4:52 pm by Jason Byrnes | 7549 views | 10 replies |
account134484
I have created an insert record form with one file field, using the instructions found here dfp_da_insert_update_ht.pdf
You can see the form at the link below.
add_homework.php
Username: support
Password: user
The problem I am having is I need the uploaded files associated with the database record, so when the student logs in to get their homework assignments, they know which files to download.
Right now I am getting an error "Column 'docs' cannot be null"
please send a copy of the page so I can examine the code.
account134484
see attachment.
There is no attachment to see.
can you add the php file to a zip archive and attach the zip file to your reply.
account134484
try this again
The heart of the issue is that you cannot do this using the Dreamweaver insert record behavior.
The Dreamweaver insert record behavior is limited in that it will only allow you to store form information in the database.
When a file is uploaded, the file field does not actually send a value, it sends the bits of the file.
The digital file pro Upload File behavior takes these bits and recreates the file on the server.
Once the file is created on the server, a php variable is created that contains the Server File Name.
You need to use the DataAssist insert record behavior to be able to use the Server File name variabel when inserting the record.
See the "How to apply Digital File Pro to DataAssist Insert and Update pages " tutorial in the how to section of the Digital File pro support page:
digital-file-pro/
account134484
Update
I have followed the steps again, but the file isn't uploading and it is not being recorded in the db.
See attachment.
1) Try using the Button Insert pressed trigger for the File Upload behavor.
2) In the insert record server behavior, bind the docs column to the Server File Name variable instead of the form element.
account134484
Update
The file is uploading to the proper folder, but when you try to download the file, it isn't linked correctly.
homework_Detail.php?homeword_id=26
uploads to here:
upload/
links to here:
register_4.pdf
instead of:
register_4.pdf
account134484
Update
I have three file fields, so users can upload more than one file. I have already followed steps to upload the first file, but I need to know how two setup the remaining two file fields and make sure they record to the same id.
