Admin Passwords Invalid in PowerStore 3
My Admin Passwords seem to be invalid...which page of code
do I check to verify or even change?
First thing to check is that session management is working correctly. See this thread for a file called sessionTest.php which can be used to test the server:
if the sessionTest.php page tests successfully, double check the wa_settings tabel in the power store database. The admin_username and admin_password records contain the user and pass.
