Session question
Thread begun 2/25/2010 12:33 pm by Paul | Last modified 2/27/2010 1:13 pm by Paul | 1871 views | 3 replies |
PaulBeta Tester
Session question
I have created a login page that captures various sessions, one being $_SESSION["ch_status"]
The value is numeric, either 1 or 2.
After the user logs in, i'd like to show session value as text instead of the value it holds.
For example..
If ch_status = 1 show "One" or if ch_status = 2 show "Two" in the page.
Would appreciate a steer on this if possible.
Thank you, Paul.
Les CrowleyBeta Tester
Quick way would be to use if then logic ..
if ($_SESSION['ch_status'] == 1) {
echo "One";
} else {
echo "two";
PHP does not have a built in function for converting an integer to the textual representation, but if you only have a few values to deal with you can create your own.
add this function to any page you want to display the number as the text equivalent:
function numText($num) {
$retNum "";
  switch(
$num) {
    case
1:
$retNum "one";
      break;
    case
2:
$retNum "two";
      break;
  return
$retNum;
the code to use the function would look like:
<?php echo(numText(isset($_SESSION['ch_statu'])?$_SESSION['ch_statu']:"")); ?>
My code above will only work for 1 and 2, you can add others if you need.
PaulBeta Tester
Thank you for both replies.
Very useful.
Paul.
