Cannot create a site due to Jave script
I cannot create a website and now get this error:
while executing onLoad wasap_wizard.thm, the following JavaScript error(s) occured:
In file "wasap_wizard":
initializeUI is not defined
Have a look at step 1:
Solving problems with Dreamweaver
146/
Unfortunately I am new to Windows 7
Could you possibly give me instructions (layman terms) how to access and delet:
C:\Users\[User Name]\AppData\Roaming\Adobe\Dreamweaver CS4\en_US\Configuration
Toni
I don't use Windows 7 but I found this tutorial:
article.aspx?p=1393064&seqNum=23
With a little research into Windows 7 I have managed to locate and delete the cache file as recommended by you and it has solved the problem.
Thank you for your support.
