PowerStore Settings will not save
Thread began 2/25/2010 3:55 am by doeydude13217 | Last modified 2/25/2010 12:03 pm by Eric Mittman | 639 views | 1 replies |
doeydude13217
Hi There
I am trying to change the Settings under Administrator. The Store and Registration emails and all the default ones and I need to change them. I also want to change the payment gateway settings to PayPal Express Only.
When I make these changes I click Save Changes at the bottom of the page but nothing happens. I log out and then back in again just to check the settings and they are back to the original. I am using a Mac and sometimes the Safari browser does not work as it should. I realise this so I have tried it on FireFox and Opera as well. And it is the sanme result. No change.
Have you tried this in a different browser to see if you get the same result?
As a test you can try adding in some code in the update part of the page to see if it is getting in there. To run this test open up the Admin > admin_settings.php page. In here just after line 11 put in a die statement with a message like this:
11:if (isset($_POST["updateGlobals_x"]))  {
12:die("got here");
When you make this change save and upload the page then test it. You should see a blank page with the "got here" message on it. If you get this it indicates that the update is triggering properly but perhaps it is not able to make the update for some reason. If you do not get this then it would indicate that the update is not being triggered. Please post back with your result so that we can determine how to proceed.
