Sculptor 3 won't take serial number
Thread begun 2/24/2010 1:40 pm by damon.barnes350392 | Last modified 2/25/2010 12:23 pm by Dani Chankhour | 4292 views | 3 replies |
damon.barnes350392
I've downloaded sculptor3 and when I use the serial number it says that it's not valid. The number is:
<serial removed>
How are you accessing the serial number window?
File -> New CSS Sculptor Page.
Copy and paste the serial number from your Download Center page, make sure not to copy any surrounding spaces. You can copy the entire string, and paste it into the first box of the serial input widow, it will automatically be broken down into the other input boxes.
If you are still having a problem, double check the title of the serial number window to make sure it is the CS Sculptor 3 serial window.
I see from your order history that you also have Sculptor v1, did you uninstall v1 from the extension manager before installing v3?
damon.barnes350392
Problem with em's and rounded layouts
I've got the serial number problem fixed. When I start a new page and select a layout I don't find any option for choosing rounded layouts or em based layouts.
Dani Chankhour
Could you send me a screen shot of what you are seeing under the design types and the designs drop down lists?
