Currency to £ for cart.php and confirm.php
Thread begun 2/24/2010 4:49 am by nicola.goodenough317043 | Last modified 2/26/2010 3:23 am by nicola.goodenough317043 | 2760 views | 3 replies |
I am new (bet you noticed from the query).
I am following the instructions in "Changing Currency in PowerStore" for PowerStore3. I am using Dreamweaver CS3 to make the changes. I have succeded with all the pages including Admin/Products_Insert.php (thanks Ben Bradley), except cart.php and confirm.php.
Am I right in assuming the files are in the root directory of PowerStore3? If so, I can see many places where there might be a currency symbol, but cannot see any dollar sign in design or code view. However, I can see in the code where it might go, for example
line 584 in cart.php: between the tags, before the start of the php echo statement
<td class="discounts"> <?php echo WA_eCart_DisplayMoney($WA_Store_Cart, $WA_Store_Cart->TotalColumn("AppliedDiscount")); ?></td>
Or am I totally on the wrong track? If so, can someone set me right?
Many thanks, Nick
i.edwards384429
Hi
I think you will find line 366 in WA_store_cart_php.php controls the £/$ sign in cart.php
HTH
Ian
yes, the cart.php and confirm.php files are in the root of the power store directory.
the code you posted uses the eCart WA_eCart_DisplayMoney function which cases the price to display using the currency symbol you specify in the eCart object.
I dont see anywhere in the cart of confirm page where the WA_eCart_DisplayMoney function is not used.
as long as the eCart object has been edited on line 366:
$WA_Store_Cart = new WA_Store_Cart_Definition("WA_Store_Cart", 0, "$", true, 2, 0, "oz", true, 2, 1, 0);
to use the currency symbol you wish, those pages should be fine:&pound;
$WA_Store_Cart = new WA_Store_Cart_Definition("WA_Store_Cart", 0, "&pound;", true, 2, 0, "oz", true, 2, 1, 0);
Many thanks. I have made the changes you suggested, and successfully uploaded them. Everything seems fine. Regards, Nick
