Power Store 3 MySql Databases kfm_Dir??
Thread begun 2/23/2010 8:38 pm by dennis372614 | Last modified 2/25/2010 1:08 pm by Jason Byrnes | 4842 views | 7 replies |
dennis372614
1.I setup power store 3 at my ISP, in MySql database for Power Store3
it has additional tables kfm_directories, I performed the exact install on my xaamp local testing server.
And it is missing all the kfm_directories tables, any reason why these are not installed locally?
Everything seems to be working locally , So not sure of the kfm_directories?
2. I want to be able to Work on my site thats is running, in Dreamweaver CS4, and using the WebAssist extensions to customize the site locally,
My plan is to FTP the entire site to my local machine and setup new site in DW,
I know I will have to modify the connection.php and Index.php to point to my local server? what other issue will I run into. or what do you suggest best method to perform this?
Dennis Sigala
The kfm_directories table is created when you use the advanced file management features of the HTML editor. If you have not used the advanced file management features on your local computer yet, that table will not heave been created.
as long as you extract the power store files to the root of the Dreamweaver site, the only thing that you should need to change is the connection information.
dennis372614
kfm tables not explained? origin
Since power store creates all the database tables, my question is why are the kfm tables created at the remote ( my hosting provider) Database and not local database.
The powerstore installer does not create the kfm tables. the advanced file manager of the HTML Editor does. See the first paragraph of my initial reply:
dennis372614
kfm tables? not using any html editor
I am not using any HTML editor, I am looking at the actual database and tables produce from the PowerStore Install wizard. both remote and local.
Not looking at tables through Dreamweaver!
I am only viewing the tables using myphp admin with MySql database at my ISP
And using the same phpadmin to view the tables locallyI do not understand
I did not use any HTML editor to install, or view!
I only run the install wizard form Power Store 3. then the database is created!
Confusing since I do not use any HTML editor!
Are you referring to PHP Admin?
"The kfm_directories table is created when you use the advanced file management features of the HTML editor. If you have not used the advanced file management features on your local computer yet, that table will not heave been created. "
In the Power Store admin section, you have the ability to add content using PowerCMS. this Uses the functionality of the HTMLEditor.
Only when you add or edit content using the content management portion of Power Store and upload a file will the kfm tables be created.
the kfm tables are created by the Advanced file management features of the HTMLEditor extension that was used to develop the content management section of the Admin portion of PowerStore.
dennis372614
Yes ! I now understand!
That expains it all, Sorry I was unable to understand it all! Now I do.
You explained it well.
Thank you for the clarification and Patience!
Dennis
No worries.
