Update security password
Thread begun 2/23/2010 1:05 pm by Remco209061 | Last modified 3/09/2010 3:46 pm by Jason Byrnes | 5724 views | 11 replies |
Remco209061
Hello I want to change a password, I followed the tutorial but it won't work.
Why?
Greats Remco
the screen shoot you sent is to small to be able to make the error message.
Can you post back with the text of the error please.
Remco209061
Hello Jason
Sorry,
this is better I hope!
grts Remco
There was no attachment.
perhaps you could copy the error text from the web page into your reply?
Remco209061
Ok again
Notice: Undefined variable: _SESSION in /Applications/MAMP/htdocs/CMS/Admin/Verander.php on line 21
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /Applications/MAMP/htdocs/CMS/Admin/Verander.php:21) in /Applications/MAMP/htdocs/CMS/Admin/Verander.php on line 31
Warning: Cannot modify header information - headers already sent by (output started at /Applications/MAMP/htdocs/CMS/Admin/Verander.php:21) in /Applications/MAMP/htdocs/CMS/Admin/Verander.php on line 40
This is the message.
Hello Jason is it better to use the User Registration pre build solution? It's the same I think.
I want to make a pre build login system that can be copied and used in other site's. But every time i have to build it again.
grts remco
try adding the following code at line 1:
error_reporting
(E_ALL);
Remco209061
Why ?
The error message is printed already.
grts remco
sorry, I ment to copy this code instead:
<?php if(!session_id()) session_start(); ?>
Remco209061
Session
Ok this starts the sessions, and it works but only one message stays.
Warning: Cannot modify header information - headers already sent by (output started at /Applications/MAMP/htdocs/CMS/Admin/Verander.php:5) in /Applications/MAMP/htdocs/CMS/Admin/Verander.php on line 39
There are no blank lines in the code!
grts remco
please send a copy of the page.
