009 From field
Thread begun 2/23/2010 11:42 am by John Langer | Last modified 2/23/2010 3:15 pm by Ray Borduin | 2351 views | 3 replies |
John LangerBeta Tester
009 From field
Let me just say that I started out with the Contact Form Solution Pack.
I deleted all references to UE from the pack and started again on the email part. This has worked well and I have it working.
A small glitch however in the From field.
Clicking on the From button on the left of the field gives you the option of inserting the name as well as the email address of who it's from. I gathered both of these from the Form binding. When the email arrives if I click reply then up pops a blank email with the return address. That's fine.
Back to the message that's arrived though and it says it's from (for example)
Fred Smith <fred@smith.comfred@smith.com>< fred@smith.comfred@smith.com >
The email is repeated.
As I say though, if I click on reply the return email address is just applied once.
Perhaps it's something to do with the Contact Form Solution Pack, I don't know. I thought I'd flag it up.
Apart from the two things I've reported I've found nothing wrong with the UE side of things.</fred@smith.comfred@smith.com>
I can't seem to reproduce that result.
What does the from field say when you open the Server Behavior?
If you drag the binding for the email header onto the page, or check the email header in the email log does it have it repeated there as well?
Hi Ray,
This is the header info from the actual received email:
Return-Path: <langerwe@server1.arooneyhosting.co.uk.>
Delivered-To: arooney-johnlanger@arooney.co.uk
Received: (qmail 31093 invoked from network); 23 Feb 2010 22:45:11 -0000
Received: from unknown (HELO server1.arooneyhosting.co.uk.) (91.204.210.182)
by mail4.interdns.co.uk with SMTP; 23 Feb 2010 22:45:11 -0000
Received: from langerwe by server1.arooneyhosting.co.uk. with local (Exim 4.69)
(envelope-from <langerwe@server1.arooneyhosting.co.uk.>) id 1Nk3Rp-0006Ac-53
for johnlanger@arooney.co.uk; Tue, 23 Feb 2010 22:41:45 +0000
To: johnlanger@arooney.co.uk
Subject: CMC Online Contact Form: General Enquiry
MIME-Version: 1.0
Content-Type: multipart/alternative; boundary="WAMULTIBREAKWA"
Reply-To: fred@smith.com
X-Sender: Fred Smith <fred@smith.com> <fred@smith.com>
X-Priority: 3
Date: Tue, 23 Feb 2010 22:41:45 +0000 (UTC)
Message-ID: <44384499.570a90bfbf8c7eab5dc5d4e26832d5b1@smith.com>
X-AntiAbuse: This header was added to track abuse, please include it with any abuse report
X-AntiAbuse: Primary Hostname - server1.arooneyhosting.co.uk.
X-AntiAbuse: Original Domain - arooney.co.uk
X-AntiAbuse: Originator/Caller UID/GID - [526 526] / [47 12]
X-AntiAbuse: Sender Address Domain - server1.arooneyhosting.co.uk.
X-AntiVirus: checked (incoming) by AntiVir MailGuard (Version: 9.0.1.9; AVE: 8.2.1.172; VDF:
7.10.4.134)
X-Avira-Antispam: Version 9.0.0.15 on arooney (192.168.2.2) settings.db:9.0.0.15.3.2 (15-02-10
09:33) global_words.db:9.0.0.15.0.1 (15-02-10 09:33) user_words.db:9.0.0.13.0.1 (05-11-09 11:56)
X-Avira-ScanDate: 02/23/10 22:46:05
X-Avira-SpamScore: ata: 0.000 bayes: 0.274 final: 0.000
X-Avira-SpamLevel: No spam
This is the out put of the header and log
MIME-Version: 1.0 Content-Type: multipart/alternative; boundary="WAMULTIBREAKWA" From: Fred Smith <fred@smith.com> <fred@smith.com> Reply-To: fred@smith.com Return-Path: fred@smith.com X-Sender: Fred Smith <fred@smith.com> <fred@smith.com> X-Priority: 3 Date: Tue, 23 Feb 2010 22:41:45 +0000 (UTC) Message-ID: <44384499.570a90bfbf8c7eab5dc5d4e26832d5b1@smith.com> </fred@smith.com></fred@smith.com></fred@smith.com></fred@smith.com>
Sending To: johnlanger@arooney.co.uk... Success
This is the actual code in the from field of the wizard:
</fred@smith.com></fred@smith.com></fred@smith.com></fred@smith.com></langerwe@server1.arooneyhosting.co.uk.></langerwe@server1.arooneyhosting.co.uk.>
<?php echo ((isset($_POST["Contact_Name"]))?$_POST["Contact_Name"]:""); ?> <<?php echo ((isset($_POST["Email_address"]))?$_POST["Email_address"]:""); ?>>
<langerwe@server1.arooneyhosting.co.uk.><langerwe@server1.arooneyhosting.co.uk.><fred@smith.com><fred@smith.com><fred@smith.com>
If you need anything else I'll be around for another 1/2 hour but I'll have to get to bed then I'm afraid (UK Time)</fred@smith.com></fred@smith.com></fred@smith.com></langerwe@server1.arooneyhosting.co.uk.></langerwe@server1.arooneyhosting.co.uk.>
Thank you. This allowed us to reproduce the problem. We will get a fix into the next build.
