How to Create discount based on State
Thread began 2/23/2010 7:02 am by anonymous | Last modified 2/23/2010 4:14 pm by Jason Byrnes | 738 views | 1 replies |
anonymous
I'm creating a cart that is part of an application process. There are discounts to applicants from 3 states (OR, WA, ID). I have a drop down in the ecart form where the state is selected. Is there a way to create a discount for applicants who select one of these three states in the form?
Thanks as always for the great support.
Tony
store the selected state in a session variable.
If you are using the checkout page that is created by the checkout wizard, the state will already be stored in session variable named "eCartCheckoutForm_state_province"
you can create a discount rule that uses this session as a trigger:
Based On Session Variable value:
if the Session Variable "eCartCheckoutForm_state_province" has a value "=" to "OR"
OR
if the Session Variable "eCartCheckoutForm_state_province" has a value "=" to "WA"
OR
if the Session Variable "eCartCheckoutForm_state_province" has a value "=" to "ID"
then set the discount calculation to the desired discount.
