error on instalation
Thread begun 2/23/2010 4:05 am by jon345516 | Last modified 2/23/2010 11:22 am by Eric Mittman | 1504 views | 1 replies |
jon345516
I have downloaded CSS sculptor plus CSS menu.
I was able to register and run the CSS sculptor then downloaded CSS menu and now the CSS sculptor will not run and gets the attached error:
while executing onLoad in wacs_quickset.htm, the following Javascript error(s) occured:
In file "was_quickinsert":
initalizedUI is not defined
since then I have removed and reinstaled CSS sculptor with not success.
Any help appreciated.
Jon
Looks like you might have a problem with the cache file, here is a link to the steps you can take to delete this file and hopefully fix the problem:
Let us know if you continue to have this issue after trying this.
