Validation errors showing when page is first opened - blank page on server
Thread begun 2/22/2010 8:16 pm by roger391472 | Last modified 2/23/2010 11:20 am by Eric Mittman | 2589 views | 5 replies |
roger391472
I started this as a new thread since it seems to be a separate problem. I built another page using the same method that I had earlier today where everything now works fine. I just built a new page and I can't keep it from displaying the validation errors when the page first opens.
I haven't tried turning on error reporting yet but I uploaded it to my server in hopes that you could view it but it's just a blank page when it's live so obviously there must be some php problems. Let me know if you want me to post or send the code somehow, it's a little over 1,000 lines so I didn't want to post it here.
Here's the sequence I used on the last time I rebuilt the page so I want to confirm that I at least have that correct.
I applied the recordset to the page first and then built the form. When the form builds it seems to apply the server behaviors OK but if I preview the page in the browser these errors show up even before I apply the insert record behavior or anything else.
Your help would be greatly appreciated as I've got to get this site live by MArch 1st.
Thanks,
roger391472
getting weirder
This is really getting weird now. I closed DW for a bit and when I came back to it the page was displaying fine on the localhost without any validation errors.
It still won't display on the host server though and I'm pretty sure I uploaded all the dependent files that would be needed. I uploaded:
Spry Assets Folder
CSS Form Builder folder
WA_DataAssist folder
WA_ValidationToolkit
plus an external css file for the page
Anyone see anything I could have missed? I can't upload the entire site.
Thanks,
You should just add in some php to the top of this page to turn on error reporting temporarily while you are debugging this page.
error_reporting
(E_ALL);
Give this a try and if the error is not something obvious to you let us know.
roger391472
Hi Eric,
I did that on the local server and it didn't report anything but I'm going back to do it again and upload to the host.
I used this one but I'll switch to your code.
ini_set('display_errors',1);
error_reporting(E_ALL|E_STRICT);
I put it on the page that's not displaying and also,
WAVT_ValidatedForm_PHP.php
WAVT_Scripts_PHP.php
Are there any others that I should add it too?
Thanks,
roger391472
Hi Eric,
Got it, it was a mysql connection problem, forgot to change the login.
Thanks for the help,
Roger
Good catch, let us know if you have any further questions or run into any problems.
